Remove_SMM... UEFI.
Re: Remove_SMM... UEFI.
I have lenovo l480 i have break the password and laptop in a error the error is bad svp stop plz help meComment
@RethoricalCheese
By comparing BIOS files from post #1480 and #1484, this "New Method" won't survive a bios update, as in new file the EFI driver with name "LenovoPromptService" with GUID "AA382865-12B0-44E5-A731-6DEF4DF34CE7" gets deleted.
Other difference was in file "SystemPpisNeededByDxeCore" with GUID "4D37DA42-3A0C-4EDA-B9EB-BC0E1DB4713B", probably due to "LenovoPromptService" DXE driver deletion.Comment
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory defaulTLast edited by SMDFlea; 04-01-2023, 07:27 AM.Comment
by GuiTiHey everyone!
I need help with my Lenovo Chromebook 100e Gen 3.
Here are the details:- Motherboard: LA-L131P
- MFG Date: 2022/01/07
- MTM: 82J80001BR
- MO: MPNXB2103001
- Factory ID: LI123
I bought a new Winbond 25Q128FVSG chip.
The chip currently on the board is the same model but with different ending letters.
I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
The Chromebook is Google account locked, and I’ve already tried everything.
I understand that I need to replace or...-
Channel: BIOS Requests ONLY!
by DynaxSCHi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent... -
by m3vuvIts a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
07-15-2024, 10:15 AM -
by CronaxFDHey guys,
Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
From what I've... -
by S70rm7r00p3rHi guys.
I am very new to this business and i have some questions. Maybe someone can help me further.
I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
- Loading...
