Remove_SMM... UEFI.
  • jujurou takara
    • Dec 2021
    • japan
    #1541
    Re: Remove_SMM... UEFI.
    Originally posted by Maxpower3
    Update V3 !! (read above)
    Only for Windows
    Fix problem with python
    Please Test and report
    This file seems to have been deleted, but is there a new version?
    • jujurou takara
      • Dec 2021
      • japan
      #1542
      There was a revised version.
      https://www.badcaps.net/forum/showpo...postcount=1444
      • casti3l
        • Mar 2014
        • 95
        • romania
        #1543
        hello. i have t460 with supervisor password and i patched the original bios, the laptop turn on, but stuck on lenovo logo , what can i do? i atached the original bios
        Thankyou
        • AAAC
          • Jan 2020
          • 459
          • Mexico
          #1544
          @casti3l
          Read this other post for the instructions:
          https://www.badcaps.net/forum/showpo...52&postcount=1
          Upon powering up, press F1 when it shows LENOVO splash screen, then type 1234 as password and follow the rest of the instructions. If after trying this it still stuck at LENOVO logo, most likely the ThinkPad DOES NOT have the Supervisor Password set, or you can use a locked hard drive for the procedure to complete.
          • pinkfish
            • Jan 2022
            • Taiwan
            #1545
            Hi, Please help patch it and the model name is Lenovo X240 i7-4600U. Thank you.
            • pinkfish
              • Jan 2022
              • Taiwan
              #1546
              It works properly after executed LENOVO BIOS AUTO-PATCHER.
              • SHADYERK
                • Jan 2022
                • Mexico
                #1547
                Hi, this is my first post in the forum, and my situation is the following:
                I have a Lenovo Laptop with this features...
                Lenovo Thinkpad T460P (Late 2015 ) intel Gen 6th
                Motherboard model : BT463-NM-A611-Rev -1.0
                BIOS CHIP:
                Winbond
                25Q128FVSQ-1549
                The BIOS has a supervisor password and it is locked. I tried to make a backup with the CH341A using a programmer clamp, apparently it was not done correctly and the .bin file is corrupt (The patch found errors). My question is the following, I hope you can clarify and help me... Can I download a clean/patch .BIN file without passwords for any T460p and flash the IC? Or is it that I necessarily need the original of my BIOS? I await your responses, thank you! Greetings!
                • bhatt
                  • Dec 2015
                  • 95
                  • pakistan
                  #1548
                  how its work ??
                  • black0hackers
                    • Jul 2020
                    • 369
                    Originally posted by Smartguru@24
                    Try this new patch method & update me
                    Can you patch x1 extream i7 8th?
                    • bigman4hacking
                      • Jul 2013
                      • 6
                      • Aswan
                      #1550
                      Working with me L570 many tthanks
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12421
                        #1551
                        BIOS CHIP:
                        Winbond
                        25Q128FVSQ-1549
                        I don't think that's a solution.
                        • RethoricalCheese
                          • Mar 2013
                          • 1519
                          • Estonia
                          #1552
                          You don't need your original file to get it working again. And all dumps are without a password. That's because password is not located in bios chips on thinkpads.
                          • jatoi
                            • Jan 2015
                            • 84
                            • pakistan
                            #1553
                            lenovo e550
                            nm-a221 pached this bios
                            • shahzad
                              • Jul 2014
                              • 6
                              • pakistan
                              #1554
                              Any solution x390 password??????????????????
                              • s2qer
                                • Jan 2017
                                • 9
                                • iraq
                                #1555
                                pls patch bios for thinkpad L560
                                  • 22135
                                  Please read the forum rules before posting https://www.badcaps.net/forum/showthread.php?t=103570
                                  Use the forum search for "L560" and read some other threads, try and do some research first before posting a bios and assuming it can be patched.
                                  • oozaki
                                    • Feb 2022
                                    • Phillippines
                                    #1557
                                    Thank you for this patch. Save my life
                                    • fraymaker
                                      • May 2021
                                      • 6
                                      • Georgia
                                      #1558
                                      Hello, I have a Thinkpad X1 Carbon 3rd Gen. (20BS) It has a fingerprint lock in bios, if I skip fingerprint check it has a bios password. Don't really know more about the bios setting, since I cannot enter bios even in read-only mode. When I enter 3 incorrect passwords it just restarts. I patched the bios file and used CH341a to write it directly on the chip. I get 5 + 5 beeps and no display. After that, I wrote original bios and it's working the same as before (locked bios). I have attached original bios and patched bios. I think it might be ME Region Lock can anyone help with it?
                                      • vignesharivuslm
                                        • Nov 2014
                                        • 33
                                        • India
                                        #1559
                                        T490, I7 8TH GEN CPU, NM-B901 PATCH PLS, DXE AUTOPATCHER NOT WORK.
                                        • ak1_2004
                                          • Oct 2017
                                          • 42
                                          • Iran
                                          #1560
                                          E595 !
                                          AutoPatcher dont work !
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
