Remove_SMM... UEFI.
  • v11
    • May 2016
    • 45
    • Electronika
    Remove_SMM... UEFI.
    Hello ... If anyone knows what software,and how to extract it,SMM from UEFI,I want to experiment,on a Thinkpad_T460s with MAX25L12873F,Please tell me if you know.
    Please Help me...
    Thanks.
    • 31877
    Re: Remove_SMM... UEFI.
    i am interested in what you find with that model.
    go to https://www.coreboot.org
    look in the wiki - they link to lots of tools for extracting and modifying content.
    • dycc
      Vision
      • Nov 2011
      • 627
      • Côte d'Ivoire
      • la maintenance
      Please Help me...
      Thanks.
      System Management Mode basics
      SMM is a special execution mode of IA-32 architecture that was introduced with i386, chapter 34 of Intel 64 and IA-32 Architectures Software Developer's Manual is the main information source about it's design and usage:
      SMM is a special-purpose operating mode provided for handling system-wide functions like power management, system hardware control, or proprietary OEM-designed code. It is intended for use only by system firmware, not by applications software or general-purpose systems software. The main benefit of SMM is that it offers a distinct and easily isolated processor environment that operates transparently to the operating system or executive and software applications.
      Some time ago SMM was used by BIOS developers mostly for power management and legacy devices emulation, for example, PS/2 support (port 60h/64h) for USB keyboard and mouse. Nowadays it's also widely used for firmware and platform security purposes.
      Why SMM is interesting for hackers?
      In UEFI specification SMM plays very important role for implementing of platform security mechanisms that protects firmware image stored inside flash chip on motherboard from unauthorised modifications by malicious software.
      SMM is excellent place to hide OS independent and invisible malware. This execution mode has extreme power over all of the other software that runs on CPU, even OS kernel or VT-x hypervisor.
      http://blog.cr4.sh/2015/07/building-...-for-uefi.html
      SMM executable code and data lives inside SMRAM and when SMRAM is locked — it can't be accessed by code of operating system or user mode software. System firmware (legacy BIOS or UEFI) copies SMM code into SMRAM and locks it during platform initialization.
      Processor is switching to SMM only trough System Management Interrupt (SMI), it saving current execution context into SMRAM and start executing SMI handler that can exit from SMM and resume execution from saved context using RSM instruction.
      • v11
        • May 2016
        • 45
        • Electronika
        In Coreboot, not found a file for this model T460s,
        I am interested,to cancel this SMM,
        not to ask for the password UEFI (bios).
        Thx.
          • 31877
          look harder, there are links to stuff like me-cleaner
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            what do you aim to acomplish? password removal or something else?
            do you have expirience in reverse engineering or have you ever coded code that can be injected in bios to be executed?
            im very interested in project... done some minor bios modding before, unlocking menus and stuff...
            but i have very limited knowledge :-/
            Im Back... sort of...
            • v11
              • May 2016
              • 45
              • Electronika
              To bypass the password,
              who is in MEC1633l.and I have minor knowledge,but with your help,I'll handle it.
              What software, to use to make a patch,other than ...UefiTool ?
              thanks.
              • v11
                • May 2016
                • 45
                • Electronika
                please give me a link for a patch for T460s 20FA ,Mx25L12873f ?
                Please Help....
                I do not find, and I've looked a lot.
                thank you.
                  • 31877
                  there is no patch - the tool is to clean the data from extracted modules.
                  you extract them with uefi-tool - clean them, then put them back in.
                  • v11
                    • May 2016
                    • 45
                    • Electronika
                    Thank you , friend...
                    br
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      MEC1633l needs to be programmed with clean firmware by SVOD or RT802H
                      on allservice.ro thay developed a module (DXE Driver) that is inserted on org bios, it reads some data and displays code that after you send to them and pay thay make you a key to unlock pemanently
                      https://www.allservice.ro/forum/viewtopic.php?t=3044
                      maybe something can be done by loading dump in IDA PRO and disabling checks but i dont have time for that (nor do i have laptop to test it on)
                      • v11
                        • May 2016
                        • 45
                        • Electronika
                        I found MMTool and UEFITool but still do not know what to delete from the file ..
                        it does not cost much to make the boys know ...
                        I want to learn to do it myself.I'm sorry i do not know english well.
                        THX.
                        • v11
                          • May 2016
                          • 45
                          • Electronika
                          I want to ask you :what is it Ozmosis ?
                          How to make Ozmosis ROM via UEFITool ?
                          thanks.
                          • raileanu
                            • Sep 2015
                            • 129
                            • Technology
                            Does anyone can upload the DXE Driver here so I can have a look and try to make it work for any Lenovo please.
                            • raileanu
                              • Sep 2015
                              • 129
                              • Technology
                              Hello. Did you manage to get a link for downloading the dxe driver or any already patched bios?
                              • fyaagoub
                                • 269
                                • maroc
                                thank you
                                • tohenk
                                  • May 2019
                                  • Indonesia
                                  There are two methods in hacking the DXE module, but please note this is untested.
                                  1. Modify the key check so it accepts any code.
                                    If you're willing to try the modified version use the file attached, and again it is untested.
                                  2. Using a key generator.
                                    From the image above, the key for machine id 2492411559 should be 7316483. Anyone with other machine id can reply here to test the key generator. Please note, the key generator also still untested.
                                  • dani981
                                    • Mar 2018
                                    • 92
                                    • Hungary
                                    Hi
                                    This key generator share. Testing
                                    hardware id: 3425684
                                    key: 8625856
                                    hardware id:7668394
                                    key:6224236
                                    hardware id:9777692
                                    key:7729864
                                    hardware id:2217972
                                    key:3089784
                                    hardware id:2292158
                                    Key:1264964
                                    hardware id:832201
                                    Key:0224961
                                    hardware id:8096698
                                    Key:3216204
                                    HW ID: 125318167
                                    Key: 292467
                                    • przemek_79
                                      • Dec 2014
                                      • 28
                                      • Poland
                                      hi
                                      I am asking for the generator to be available so that I can test it
                                      • imranromi
                                        • Jan 2015
                                        • 1297
                                        • Pakistan
                                        Originally posted by dani981
                                        Hi
                                        key: 8625856
                                        hardware id:7668394
                                        key:6224236
                                        hardware id:9777692
                                        key:7729864
                                        hardware id:2217972
                                        key:3089784
                                        hardware id:2292158
                                        Key:1264964
                                        hardware id:832201
                                        Key:0224961
                                        hardware id:8096698
                                        Key:3216204
                                        HW ID: 125318167
                                        Key: 292467
                                        Yes all hwid and key is 1st patch algorithm 2 more have algorithm
                                        • cy2u5
                                          UEFI Password Help needed | X1 Carbon Gen9
                                          by cy2u5
                                          Hi guys
                                          I read many threads now and I am actually overwhelmed and confused.
                                          My machine:
                                          Lenovo ThinkPad X1 Cabon Gen9
                                          System Unit Serial No.: PF3TQ7W3
                                          System Board Serial No.: L2HF26L002B
                                          Board No.: NM-D341
                                          Revision: Rev. 1
                                          It had a faulty CPU (shorted), so I bought a password locked one on ebay. Device runs up and workd but I want to remove the UEFI lock.
                                          - I learned that my Lenovo has a MEC1503 and can't be unlocked by the patcher tool (https://www.badcaps.net/forum/troubl...es-and-electro...
                                          05-24-2026, 04:28 AM
                                        • maurinaz
                                          Request: NVIDIA MATS/MODS UEFI payload for RTX 4070 Laptop (GN22-X11 / AD107)
                                          by maurinaz
                                          Hello everyone!
                                          I need the UEFI-compatible version of NVIDIA MATS/MODS to test VRAM on a
                                          laptop RTX 4070 GPU (GN22-X11 / AD107). My MSI Stealth 16 Studio laptop
                                          is UEFI-only (no CSM), so I specifically require the mats.efi payload
                                          that works on Ada GPUs.
                                          Local repair technicians here do not have MATS/MODS versions that support
                                          RTX 40 series, so I need the proper UEFI build (v2.0.0 or newer).
                                          If anyone can share the correct MATS/MODS package for Ada (UEFI boot),
                                          or any documentation on how to run mats.efi on RTX 4070 Laptop GPUs,...
                                          12-10-2025, 03:08 PM
                                        • 4nubis
                                          Surface Laptop 4 1950:1951 DFCI Locked
                                          by 4nubis
                                          Hello!
                                          I recently bought a second hand laptop and i've found mysel in same situation of this user:
                                          https://www.badcaps.net/forum/troubl...79-dfci-locked
                                          When i booted up the pc the first time i saw an open lock on red background and that's when i found out about secure booting and secondly down the bios rabbit hole.. Honestly i'ts a bit out of my knowledge because i've mever messed around with this kind of stuff and before this...
                                          07-11-2026, 05:58 AM
                                        • GuiTi
                                          Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                          by GuiTi
                                          Hey everyone!
                                          I need help with my Lenovo Chromebook 100e Gen 3.
                                          Here are the details:
                                          • Motherboard: LA-L131P
                                          • MFG Date: 2022/01/07
                                          • MTM: 82J80001BR
                                          • MO: MPNXB2103001
                                          • Factory ID: LI123
                                          I bought a new Winbond 25Q128FVSG chip.
                                          The chip currently on the board is the same model but with different ending letters.
                                          I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                          The Chromebook is Google account locked, and I’ve already tried everything.
                                          I understand that I need to replace or...
                                          10-14-2025, 08:41 AM
                                        • DynaxSC
                                          Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                          by DynaxSC
                                          Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                          For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                          06-10-2023, 11:30 AM
