Lenovo B590 bios needed
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Lenovo B590 bios needed
    Originally posted by emimilu
    I use CH431 and the chip is detached from the board.
    I strongly advise you to use AsProgrammer_2.0.0a14, NeoProgrammer V2.2.0.8, or Colibri.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • poweron
      • May 2019
      • 371
      • italy
      lenovo B590 bios bin
      hello, this is the backup of the bios, how can I see if it is corrupt and possibly rebuild it?
      thank you
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Re: lenovo B590 bios bin
        thank you
        Why do you ask that? What problem do you have with your machine?
        • poweron
          • May 2019
          • 371
          • italy
          because before it turned on with difficulty sometimes you had to remove and reinsert the bios battery, now not even in this way
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            So what you are waiting for - try Peste's file, or the one at post #3 uploaded by Mcplslg123 it's confirmed working, and Peste's dump is virgin file extracted from Lenovo website, if the problem persist, obviously your issue is not bios related.
            But before that check power button functionality. Is it working properly? 3.3 volts present on it? Does the voltage drop to zero when the button is pressed? Come ooooon these are basic things. Why haven't you checked them by now, instead of taking out the bios battery all the time, and relying on board auto-start functionality?
            • poweron
              • May 2019
              • 371
              • italy
              #26
              yes, I know, the 3.2 on the power button are there and go to 0v so I wanted to try with other bios
              • poweron
                • May 2019
                • 371
                • italy
                #27
                i tried the bios of Mcplslg123 and it works
                Thank you
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #28
                  Thank you
                  You're welcome.
                  • hopkok
                    • Oct 2014
                    • 178
                    • Slovakia
                    #29
                    Hi, anyone able to remove WLAN whitelist from BIOS backup? Need to replace wireless card, because Broadcom one has problems in windows 10. Thank you
                    • baki60
                      • May 2020
                      • 78
                      • Türkiye
                      #30
                      What is loading on the 4mb one
                      • metlj
                        Mehdi
                        • Jan 2023
                        • 18
                        • america
                        #31
                        hi black screen issue in w10 when installing intel hd
                        i tried any of this files that u've posted but same problem
                        • ianbak
                          • Apr 2023
                          • 55
                          Lenovo B590 BIOS Help Requested
                          Hi, I could do with some assistance in finding the right BIOS for a Lenovo B590/LA58 11273-1.
                          The laptop in question corrupted its BIOS during a failed upgrade and, sadly, none of the original data seems to have survived.
                          I programmed an alternative BIOS that I found on here, which kind of worked - the laptop came back to life but the disc interface wasn't functioning. At this point I discovered that there were three different BIOSes for the same laptop, depending on the version, and I now had an H9 main BIOS but an H1 EC BIOS.
                          I assume that that means that I need an H1 main BIOS to go with the existing EC BIOS, but I can't find a copy of one of those. Lenovo publish a Zip file (h9et75ww.zip) and an executable (h9et84ww.exe - don't want to publish any unallowed links!) that both contain the three different versions, but I can't work out how to use what is in there to produce a programmable H1 file.
                            • 21606
                            Re: Lenovo B590 BIOS Help Requested
                            You MUST:
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12240
                              #34
                              Even if the update fails, the bios is still there and cannot be lost until you arbitrarily write a strange bios into it.
                              ​https://www.badcaps.net/donate
                              • ianbak
                                • Apr 2023
                                • 55
                                You're welcome to have a look at what I saved, but since I couldn't open it in UEFITool I assumed that it was beyond hope...
                                  • 21606
                                  serial number
                                  • ianbak
                                    • Apr 2023
                                    • 55
                                    Originally posted by SMDFlea
                                    serial number
                                    P/N is 59410685
                                    S/N is WB14742312
                                    Yeah, should have included that first time round. I'm still learning...
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12240
                                      #38
                                      P/N is 59410685
                                      S/N is WB14742312
                                      B590 Laptop (Lenovo) - Type 6274
                                      • ianbak
                                        • Apr 2023
                                        • 55
                                        That has worked perfectly. Thank you so much!
                                        • cygron
                                          • Oct 2017
                                          • 25
                                          • Myanmar
                                          #40
                                          Need Lenovo B590 Laptop Type 6274 EC BIOS. Please help.
                                          • lucaszmn
                                            by lucaszmn
                                            Problem:
                                            Initial Findings:
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • grimacelord
                                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                            by grimacelord
                                            Hello there.
                                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                            History:
                                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                            I searched for this error online and discovered...
                                            03-15-2023, 03:29 PM
                                          • bbusterscruggs
                                            Lenovo B590 20208 Bios Problem
                                            by bbusterscruggs
                                            Hello, I wanted to update my laptop's BIOS from h1et40ww to h9et92ww. The website says I need to install h9et75ww first, so I tried installing that version first, but the installation failed and when I press the power button, the laptop momentarily turns on and off (the power light immediately flashes). I tried the crisis files with Fn+R but they didn't work (it works for about 30 seconds with Fn+R but nothing displays on the screen). How can I get a BIOS update file that I can use with Fn+R? Maybe I'm naming the files I put on the USB drive incorrectly. The ones I've tried are bios.bin, bios.cap,...
                                            09-15-2025, 11:57 AM
                                          • cyber16
                                            Lenovo P1 g1 Type 20MD-002PUS "BIOS Help Needed"
                                            by cyber16
                                            Please I need help.
                                            Quick rundown long story shorter, but still long winded.
                                            I received this Lenovo P1 GEN 1 about a year ago from a business.
                                            It was pretty much dead hit the power button and the LED on the power light would come on as would the keyboard back light a couple times and just shut off or go into high speed fan mode without life other than the power button led.
                                            At that time it was still under warranty, I spoke to Lenovo and I was going to send it in to have them repair it.
                                            Then late last fall my father-in-law suffered...
                                            09-08-2022, 07:32 AM
