lenovo B590it turns on only the first time but remains off afterwards
  • poweron
    • May 2019
    • 371
    • italy
    hello, this lenovo turns on the first time but then stays off, if I remove the 3v bios battery it turns on and works, but if I try again after turning it off it does not turn on again, I must first remove the bios battery, here too the bios from the lenovo site, but I have not solved
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: lenovo B590it turns on only the first time but remains off afterwards
    What is the mb code?? Schematic available?? Seems like RTC Section fault.
    • poweron
      • May 2019
      • 371
      • italy
      i also have doubts about rtc
      • poweron
        • May 2019
        • 371
        • italy
        problem solved, it was the corrupted bios, thanks
        https://www.badcaps.net/forum/showth...t=63193&page=2
        • riko 656
          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
          by riko 656
          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
          Laptop Model:
          • Model: Lenovo Legion Slim 5 16APH8
          • GPU: NVIDIA GeForce RTX 4070
          • Main BIOS chip size: 32MB
          • VBIOS chip size: 16MB
          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
          What I Have Tried So Far:
          1. I
          11-04-2025, 05:14 AM
        • nieljosiah
          HP Notebook - 15-ba017ax (LA-D711P Motherboard) turns off randomly after some time
          by nieljosiah
          I've had this laptop for 8-9 years, and about a week back, it started malfunctioning. When I press the power button, the power LED comes on for about 5secs and turns off. The fan also doesn't spin at all during this time. But, if I press the power button, and then manually spin the fan, the laptop boots up and the fan starts spinning on its own. Even if I do this, and the laptop boots up, it turns off (hard shutdown) after some time between 10secs and 1hour randomly. I've tried checking the fan voltage and it's at zero volts when I press the power button without spinning it, but when I spin the...
          08-17-2024, 02:19 AM
        • twonk9098
          Lenovo Legion 5 high fan spin turns off after 34 seconds
          by twonk9098
          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
          I have tried a few new bios but exactly...
          07-14-2024, 11:19 AM
        • anton brunner
          Having a hard time dumping BIOS - Lenovo Ideapad Duet 3 (11IAN8)
          by anton brunner
          I'm having a hard time dumping the BIOS of a Lenovo Ideapad Duet 3 (11IAN8). The chip is a Winbond W25R256JVEN, directly soldered to the board in a WSON8 package.
          Since there are lots of tiny components near the chip, I was hesitant to desolder it using hot air. Instead, I soldered thin wires directly to the chip's pads and connected them to a CH341A programmer (photos attached).
          The chip is detected correctly in both NeoProgrammer and ASProgrammer, but I'm unable to get a consistent dump. I've tried over 15 times — shortened the wires to...
          05-15-2025, 01:01 AM
        • ferah831208
          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
          by ferah831208
          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
          03-18-2025, 01:18 AM
