Lenovo P1 g1 Type 20MD-002PUS "BIOS Help Needed"
  • cyber16
    • Oct 2021
    • 16
    Please I need help.
    Quick rundown long story shorter, but still long winded.
    I received this Lenovo P1 GEN 1 about a year ago from a business.
    It was pretty much dead hit the power button and the LED on the power light would come on as would the keyboard back light a couple times and just shut off or go into high speed fan mode without life other than the power button led.
    At that time it was still under warranty, I spoke to Lenovo and I was going to send it in to have them repair it.
    Then late last fall my father-in-law suffered a stroke and fell and broke his hip and for the next five months I was there daily helping him during his recovery. During this time the warranty expired early this year 2022.
    So I started doing some searching and I think it boiled down to the thunderbolt setting within bios may have screwed up the main bios. Therefore I made five dumps of the main 32mb bios and they all matched.
    I found a donor bios online that I installed and it gave the laptop life, it was a 1.19 ver. Went through some windows updates and I took some firmware updates as well and it's working wonderfully except for the fact that when you turn it on there's a painful delay of approximately 20+ seconds or so before it comes to life with the lenovo splash other than the power led on. The current bios ver is now at 1.41
    According to the bios the ME is the culprit as its blank no version. I have made several attempts to correct this problem without any luck, failed cleaning it.
    Can someone take a look at this donor bios and maybe assist me in cleaning the ME region.
    Or do you see a different problem?
    I tried to do it myself and failed many times with ME Analyzer v1.274.0 r277
    ME Analyzer would crash every time I tried to read the original dump, it does read the current firmware.
    I really don't know what I am actually doing, I have watched many guides.
    I did also flash the thunderbolt chip early and that is working fine, I did not zero it out first, the laptop itself is working fine other than the painful slow post..
    *This is the actual info is from the label on the back cover
    *Lenovo P1 g1 Type 20MD-002PUS
    *SN# R9-0SVG0B 18/12
    8th Gen Intel i7-8850H
    GPU's Intel 630 + NVVIDIA P1000 "Both work"
    Does have thunderbolt "works well"
    Does have fingerprint bio "works"
    No errors found under diag.
    The upload is the ver. 1.41 bios currently working with slow post:
    Below info is from within Bios setup screen
    UEFI BIOS Version N2EET59W (1.41)
    Embedded Controller Version N2EHT30W (1.15)
    ME Firmware Version is empty
    Machine Type Model 20MD002PUS
    System-unit serial number "R90SVG0B
    System board serial number W2KS8CL10L2 "I don't know if its right or wrong, not sure where to find it
    I remover the cover many times and if it was a label, it may have fallen off.
    Same as the board model number? not sure where that is either.
    I am using a Rasberry PI
    I always take 3-5 backup dumps and compare
    I have done a lot of PCs and Macs in the past without an issue, but the ME is a struggle for me, not even sure if that's the cause of slow post. Maybe the EC region?
    The original corrupt dump could not even be opened within ME Analyzer, machine was basically dead.
    I will include the original dump called OEM.bin and the current working dump called slowpost.bin
    Please can someone help or supply a clean dump for this P1?
    Again, the OEM dump will NOT post at all.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12413
    Re: Lenovo P1 g1 Type 20MD-002PUS "BIOS Help Needed"
    Clean ME file or new one
    • cyber16
      • Oct 2021
      • 16
      wow thank you, I am going to give it a try now.
      I am actually using this laptop for this post/thread.
      Fingers crossed, will report back
      edit:
      THANK YOU SO VERY MUCH!
      I was in such a hurry, I shut down before I even downloaded your cleanME file. lol
      It works perfectly.
      First power on cycled on off a couple times with splash screen
      then it booted just fine.
      Shut it down and hit the power button, within a second or two the lenovo splash came up
      and its working fine!
      Within bios screen the ME firmware version is now populated with info
      This laptop was headed to the recycler, the biz was not even going to spend time sending it in for warranty repair. They stripped the drives out and the battery.
      So I had to purchase a few things to get it back working.
      Now I also need to address one bad memory slot, that only works if pressure is applied to the DIMM in that slot.
      Again, thank you, I have spent so many hours trying to correct this painful post time and the ME
      • zia32
        • Oct 2023
        • Pakistan
        Originally posted by cyber16
        Please I need help.
        Hey there, How are you? I want to know that how did you flashed the bios? How ere you able to attach the Spi programmer clip with the bios chip sine the contact points are different.
        • Joluvillas
          Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
          by Joluvillas
          Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
          06-18-2024, 10:35 PM
        • AHmad_Salal
          Need BIOS Dump/ROM for Lenovo Thinkstation p500
          by AHmad_Salal
          Hello all,
          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
          11-28-2023, 05:28 AM
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
        • TacticalFahrrad
          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
          by TacticalFahrrad
          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
          06-30-2025, 04:09 AM
        • hirens
          Lenovo ideapad 3 14IGL05 bios dump needed
          by hirens
          model: 81wh
          sn: pf36ta6h
          board no: nm-c961 gs453/gs553
          hey guys above is my laptop info
          it only blinks the power button kindly help me with a working dump
          old dump attached...
          07-21-2023, 04:48 AM
