Please can anyone help me with this dump 10245-2 Q15 Intel mb
					Dell Vostro 3550 bios
 Re: Dell Vostro 3550 bios
 HELLO all ,
 Need dump file bios version A12 .
 My battery is Dead ,I cannot update with windows
 i need to put w10 otherwise blackscreen after drivers
 Can someone extract me the dump from the original exe DELL
 ThanksAttached FilesComment
 Extract it using the the command line,as admin.Change to the directory where you have the exe then type the command,and enter
 3550A12.EXE /writeromfileComment
 I will test this. Thank you
 edit :OK good perfect ,thanks
 I didn't dare to do it before lolAttached FilesComment
 Press FN + x it should make the message go away.Comment
 good day every one, only charge battery and dont power up
 Model: Vostro 3550
 servTag: JRKG9S1
 MoBo: 10245-1
 48.4IE01.011 DQ15
 DP/N: XYW0CBR-0XYW0C-10819-1AP-00EX-A01
 ​Attached FilesComment
 something is going wrong, I programmed it twice.., at the first start it generates the black screen where it asks to continue pressing fn+x, nothing is done, everything restarts, it only enters the bios screen and it doesn't let me set the time, I can only hear the Keyboard bbeps does not fill in the time or date fields, I press the power button for 5 seconds. to turn off then it only beeps as if it had a Ram Memory problemfan spinning and black screen after second reboot, and I used the file named 3550a12.rar that was provided at some point to Maxpower3 and it is not working for meComment
 You can forget my post I solved with the 3550a12.rar file, it was just that the Tsop8 (MXIC 25L3206E) would be defective, I replaced it with a (WinBond 25Q32FV) and the old warrior is now working again, thank you very much for those who took interestComment
 Can somebody unlock this dump for me? It has admin pass. I tried few generators, but no lucky.
 Dell Vostro 3550
 S/N 5YVCP1
 MB - 10757-1
 48.4IF04.011Attached FilesComment
 I was on that site, but i did not get any pass. Maybe i did something wrong. I will try it again later. Thanks.Comment
							Channel: BIOS Requests ONLY!
			by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
 Model: Dell Vostro 3405
 Tag:F0B1YF3
 CPU:Ryzen 3500U
 Thanks in advance-
			by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...-
 04-23-2025, 04:30 PM
			by capoplaysHey everyone,
 I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
 The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
 When I check the BIOS using the F12 menu Flash...-
			by Akhlz001Hi,
 Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
