Dell Vostro 3550 bios
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Please can anyone help me with this dump 10245-2 Q15 Intel mb
  • kazia
    • May 2015
    • 145
    • indonesia
    Re: Dell Vostro 3550 bios
    here..
    • bluestone
      • Jun 2011
      • 343
      • Ghana
      thanks bro
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1226
        • France
        Originally posted by bluestone
        thanks bro
        HELLO all ,
        Need dump file bios version A12 .
        My battery is Dead ,I cannot update with windows
        i need to put w10 otherwise blackscreen after drivers
        Can someone extract me the dump from the original exe DELL
          • 20902
          Originally posted by Maxpower3
          HELLO all ,
          Extract it using the the command line,as admin.Change to the directory where you have the exe then type the command,and enter
          3550A12.EXE /writeromfile
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1226
            • France
            I will test this. Thank you
            edit :OK good perfect ,thanks
            I didn't dare to do it before lol
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1226
              • France
              What is missing Service tag SN?
              edit :ok good just put Service tag
              it's ok like that??
                • 20902
                Press FN + x it should make the message go away.
                • ahmed666
                  • Oct 2021
                  • 4
                  • behera
                  thanks MAY bro
                  • the Benninger
                    • Nov 2022
                    • 189
                    • venezulan
                    good day every one, only charge battery and dont power up
                    Model: Vostro 3550
                    servTag: JRKG9S1
                    MoBo: 10245-1
                    48.4IE01.011 DQ15
                    DP/N: XYW0CBR-0XYW0C-10819-1AP-00EX-A01
                      SMDFlea commented
                      Editing a comment
                      Thread merged.
                  • the Benninger
                    • Nov 2022
                    • 189
                    • venezulan
                    something is going wrong, I programmed it twice.., at the first start it generates the black screen where it asks to continue pressing fn+x, nothing is done, everything restarts, it only enters the bios screen and it doesn't let me set the time, I can only hear the Keyboard bbeps does not fill in the time or date fields, I press the power button for 5 seconds. to turn off then it only beeps as if it had a Ram Memory problemfan spinning and black screen after second reboot, and I used the file named 3550a12.rar that was provided at some point to Maxpower3 and it is not working for me
                    • the Benninger
                      • Nov 2022
                      • 189
                      • venezulan
                      You can forget my post I solved with the 3550a12.rar file, it was just that the Tsop8 (MXIC 25L3206E) would be defective, I replaced it with a (WinBond 25Q32FV) and the old warrior is now working again, thank you very much for those who took interest
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • 417731
                        BIOS needed for Dell Vostro 3405
                        by 417731
                        Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                        Model: Dell Vostro 3405
                        Tag:F0B1YF3
                        CPU:Ryzen 3500U
                        Thanks in advance
                        07-06-2025, 06:48 PM
                      • mikeybass
                        by mikeybass
                        04-23-2025, 04:30 PM
                      • sammus540
                        Dell Vostro 3420 BIOS Password Removal
                        by sammus540
                        I have a Vostro 3420 8H8K5R3​-8FC8 that freeze at any attempt to enter bios password or the recovery master password received from dell. I do not have a clean BIOS image to flash.
                        And as luck would have it happened a couple of months ago right outside of the warranty period (Dec 2023) warranty expired in September. Any help or guidance is appreciated.
                        03-28-2024, 06:33 PM
                      • jhanra
                        by jhanra
                        in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                        11-02-2024, 04:19 AM
