Dell Vostro 3550 bios
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Please can anyone help me with this dump 10245-2 Q15 Intel mb
  • kazia
    • May 2015
    • 145
    • indonesia
    Re: Dell Vostro 3550 bios
    here..
    • bluestone
      • Jun 2011
      • 343
      • Ghana
      thanks bro
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1375
        • France
        Originally posted by bluestone
        thanks bro
        HELLO all ,
        Need dump file bios version A12 .
        My battery is Dead ,I cannot update with windows
        i need to put w10 otherwise blackscreen after drivers
        Can someone extract me the dump from the original exe DELL
          • 22293
          Originally posted by Maxpower3
          HELLO all ,
          Extract it using the the command line,as admin.Change to the directory where you have the exe then type the command,and enter
          3550A12.EXE /writeromfile
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1375
            • France
            I will test this. Thank you
            edit :OK good perfect ,thanks
            I didn't dare to do it before lol
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1375
              • France
              What is missing Service tag SN?
              edit :ok good just put Service tag
              it's ok like that??
                • 22293
                Press FN + x it should make the message go away.
                • ahmed666
                  • Oct 2021
                  • 4
                  • behera
                  thanks MAY bro
                  • the Benninger
                    • Nov 2022
                    • 189
                    • venezulan
                    good day every one, only charge battery and dont power up
                    Model: Vostro 3550
                    servTag: JRKG9S1
                    MoBo: 10245-1
                    48.4IE01.011 DQ15
                    DP/N: XYW0CBR-0XYW0C-10819-1AP-00EX-A01
                      SMDFlea commented
                      Editing a comment
                      Thread merged.
                  • the Benninger
                    • Nov 2022
                    • 189
                    • venezulan
                    something is going wrong, I programmed it twice.., at the first start it generates the black screen where it asks to continue pressing fn+x, nothing is done, everything restarts, it only enters the bios screen and it doesn't let me set the time, I can only hear the Keyboard bbeps does not fill in the time or date fields, I press the power button for 5 seconds. to turn off then it only beeps as if it had a Ram Memory problemfan spinning and black screen after second reboot, and I used the file named 3550a12.rar that was provided at some point to Maxpower3 and it is not working for me
                    • the Benninger
                      • Nov 2022
                      • 189
                      • venezulan
                      You can forget my post I solved with the 3550a12.rar file, it was just that the Tsop8 (MXIC 25L3206E) would be defective, I replaced it with a (WinBond 25Q32FV) and the old warrior is now working again, thank you very much for those who took interest
                      • Milovanovic1992
                        • Aug 2024
                        • 31
                        • Serbia
                        Can somebody unlock this dump for me? It has admin pass. I tried few generators, but no lucky.
                        Dell Vostro 3550
                        S/N 5YVCP1
                        MB - 10757-1
                        48.4IF04.011
                        • Milovanovic1992
                          • Aug 2024
                          • 31
                          • Serbia
                          Dell Vostro 3550
                          S/N 5YVCP1
                          MB - 10757-1
                          48.4IF04.011
                          Sorry. SN is 5YVCJP1
                          • LBTT1121
                            • Nov 2024
                            • 1241
                            • Việt Nam
                            try https://bios-pw.org/
                            • Milovanovic1992
                              • Aug 2024
                              • 31
                              • Serbia
                              I was on that site, but i did not get any pass. Maybe i did something wrong. I will try it again later. Thanks.
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • 417731
                                BIOS needed for Dell Vostro 3405
                                by 417731
                                Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                                Model: Dell Vostro 3405
                                Tag:F0B1YF3
                                CPU:Ryzen 3500U
                                Thanks in advance
                                07-06-2025, 06:48 PM
                              • mikeybass
                                by mikeybass
                                04-23-2025, 04:30 PM
                              • capoplays
                                Help with BIOS update on Dell G15 5515 after chip replacement
                                by capoplays
                                Hey everyone,
                                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                When I check the BIOS using the F12 menu Flash...
                                10-24-2025, 06:53 AM
                              • evolpe
                                BIOS DELL VOSTRO 3500 (GDI5A LA-K033P)
                                by evolpe
                                Hi guys, can anyone help me with this bios? It needs to be cleaned.
                                Motheboard: GDI5A LA-K033P REV 1.0 (A00)
                                Service TAG: BNV5GD3
                                I've attached the two BIOS (16MB and 8MB). The laptop turns on but only displays a backlight. I tried another BIOS and it works fine, but I can't exit manufacturing mode. Thanks to anyone who can help me....
                                11-11-2025, 02:16 PM
