Please help!! Bios dump Dell Latitude E6430
    Re: Dell E6430 Dump of A18 Bios
    Hi there,
    Just want to thanks GrafZahl for the E6430 BIOS dump A18 (for integrated graphics) it is working...the laptop is back to life !!!
      Re: Please help!! Bios dump Dell Latitude E6430
      thank you so much guys
        Originally posted by ridamouh159 View Post
        here is
        2 years later your bios is still saving laptop lives
        Thank You!
          try with this if not you must rebail the chip
          thank you verry much ...file working 100%
          must programm two chip (U53+U52)
            Originally posted by ovyyman View Post
            i was try this bios , i have the same problem , its start but no image, the main problem was a shortcircuit on 1,5v power supply line , a small capacitor was broken , but first i was try to change bios and i broke the cip with airflow , maybe the poblem is another now , thanks much for replay
            how did you find out this, or where was it located so maybe I am lucky
            thx
              big thanks
                Originally posted by imranromi View Post
                Try this.
                thanks
                  thanks
                    not worked
                      here is
                      thinks its ok
                        Thanks you ridamouh159 Is alive!!!!!
                          thanks
                            thanks
                              thanks a lot, its worked.
                                Originally posted by AMN servis View Post
                                Working bios dump.
                                thanks works ok
                                  thank you
                                    thank you. it worked
                                      Originally posted by GrafZahl View Post
                                      It is not possible to deactivate signed firmware update on the E6430 and newer models.
                                      Anyway I solved my problems. I bought another E6430 updated it to A18, made a dump and flashed it on the one I had problems with. Worked as expected.
                                      I attached the Bios Dump of both eeproms (U52+U53) if anybody else needs it.
                                      It recent Version A18 and does not contain a password.
                                      It is from a Dell Latitude E6430 with integrated Intel Graphics. I don't know if this works with E6430 with Nvidia or AMD Graphics.
                                      hi about e6430 bios dump with a18 you posted. can you tell me the board code of your motherboard. im looking for e6430 with board code QAL80 - LA- 7781p. i had problem when i turn on it no display, fan working then not long after that it turn off and i turn on again all 3 led indicator blinking and not longbafter that it turn off.
                                        Originally posted by caterpillar
                                        hi can you tell me your board code of motherboard? im looking for e6430 intel graphic with board code QAL80 - LA- 7781p
                                        post both original bios ..
                                          hai what that mean? im looking for bios e6430 integrated intel. code board QAL80 - LA- 7781p. i hope you can help me buddy. im newbie on this thing
