Asus R751L Black Screen (MB: X750LB) bios
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello Guys,
    I have a asus r751L with black screen, i'm suspecting a corrupted bios.
    Anyone here with a working Bios Dump ?
    Motherboard is MB: X750LB
    Thank you
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Asus R751L Black Screen (MB: X750LB)
    Anyone with a dump for Asus R751LN Please ?
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      read and post old dump i might be able to fix it
      Im Back... sort of...
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        Here we go Buddy
        PS: i've found a dump, pc boot's but i don't have picture on hdmi or internal, only vga, i guess that the mobo is "dead" ?
        • passete
          Living=Sharing
          • Jun 2015
          • 487
          • France
          Thanks to a very kind member of this forum, i was able to activate win 8 with key from my corrupted bios.
          Everything is working, second gpu (nvidia 840M 2gb) is detected and driver is installed, but i can't get a picture on the hdmi or internal display, only the subd15 (VGA) is working with external monitor.
          What it can be the problem ? never see this one before !
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            sorry i forgot
            try this
            i hope this is your original dump (non working) or may fix wont help at all
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              sorry i forgot
              try this
              Yes, this is the original corrupted dump, was from this dump that a member here extracted the win8 key.
              Do you think that the problem now, is bios related ?
              As laptop is working, all except hdmi and internal display ?
              Cause if it's not bios related, i'm stuck.
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                it might be bios
                it might be ME region needs rebuild but in this case i havent done so but i can if needed
                it may also be hardware problem... working on VGA and not working on digital ports like DVI or HDMI (assuming software and driver configured ok) may also indicate problems like VGA needs reflow or so...
                • passete
                  Living=Sharing
                  • Jun 2015
                  • 487
                  • France
                  it might be bios
                  I don't want to abuse of your kindness, but can you redo the bios with ME rebuild, like that i will test with and without.
                  Another wierd thing, when i connect the hdmi out to my monitor, the monitor doesn't detect the hdmi, and switch to dvi or vga.
                  Normaly, even with a laptop turned OFF, when i connect a hdmi to monitor, monitor detects that hdmi is connected but turns off, because there is no signal.
                  But in this case, it doesn't detect anything from the hdmi output.
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    never build me on me9.5 before, noone reported problems
                    anyway here it is
                    do you know history of the laptop? did HDMI work before?
                    • laptopnguyenhuu
                      • Apr 2015
                      • vietnam
                      thank you
                      • Schmißa
                        • Aug 2017
                        • Deutschland
                        Asus R751L doest work
                        • Hexel
                          • Jan 2019
                          • 15
                          • Ukraine
                          Re: Asus R751L Black Screen (MB: X750LB) bios
                          It has been a long, but I had similar case today, X750LB black screen, no CPU voltages, only 3/5V stand by. Last posted here dump did a job, but with code 10 on chipset device, 8086/9c18, no discreete nVidia VGA and random notebook shutdown. So, i`ve updated my broken dump with clean ME 1628 and main update from Asus site, and for now it works fine. May be of someone interest
                          • pcrepai
                            • Jul 2021
                            • 46
                            • Nederland
                            Hi guys, I have a question, I have the same laptop with the same issue starting up nothing on screen, Ive measured board everything looks fine, but as far as I can see somebody tried to flash bios and for 100% its not the original one, can someone give me any advice what now, like I understatnd u need old dump to clean Me but what in this situation if I dont have it ??
                              • 21932
                              Post the laptop serial number, your bios backup (even if it is the wrong one) and a picture of the white barcode stickers on the motherboard
                              • pcrepai
                                • Jul 2021
                                • 46
                                • Nederland
                                okay, all I could find in attachments, as you can see sticker looks bad, sorry man but this is how I get this laptop, obviously somebody tried to fix it You can see flux etc but its not a point, If you can help me Ill be gratefull.
                                  • 21932
                                  Try this one.If it doesn`t boot i don`t think its a bios problem.
                                  • pcrepai
                                    • Jul 2021
                                    • 46
                                    • Nederland
                                    Well it didn't boot ,I mean it boots but no picture. Anyway thanks for trying,
                                    • Technodoc
                                      ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                                      by Technodoc
                                      Asus laptop G614JZ-N3012W Rog Strix with i7
                                      Mainboard G634J-PMV-VGT
                                      6050A3441302-MB-A01
                                      2023-02-10
                                      Power button works okay....power light goes on
                                      Red "bottom" leds go on
                                      Charging led works
                                      Fans do not spin, capslock key does nothing, screen stays black
                                      I would like to program the bios again, to rule out a corrupted bios.
                                      However I run into a size error
                                      The bios chip is a Winbond 25R256JVEN
                                      Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                                      02-24-2025, 04:46 AM
                                    • razor_amd
                                      by razor_amd
                                      12-15-2020, 07:07 PM
                                    • grimacelord
                                      by grimacelord
                                      07-10-2025, 02:52 PM
                                    • mitchw
                                      HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                                      by mitchw
                                      Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                                      After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                                      After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                                      I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                                      04-29-2025, 03:45 PM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
