HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
  • mitchw
    • 152
    • Slovenia
    Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
    After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
    After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
    I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions with no avail.
    It says: "The BIOS recovery files cannot be found or the files are corrupted.". If I use the same version BIOS it does recovery, but it does not solve the problem, as it just reflashes the same version.
    Tried reading the bios with SOIC clip and always get bad reads, also the chip is 1.8V version. If I get a successful read, I will attach it here
    Can anyone help?
    • 21969
    Can anyone help?
    Desolder it and put it on/in an adapter. Why struggle with a clip
    • mitchw
      • 152
      • Slovenia
      I desoldered it, and of course I now got a good read.
      I then flashed the blank (recovery) image as it was 16MB image with no branding data, and it updated the EC at startup.
      And there was now image on display.
      I then figured I should flash the original dump back and it worked!
      So most likely the EC didn't get flashed and this is why there was no image on display...
      • mikeybass
        by mikeybass
        04-23-2025, 04:30 PM
      • AgustinLorenzo
        [BIOS REQUEST] HP Pavilion 15-BS521TU - Black screen after update BIOS to F.73
        by AgustinLorenzo
        Hi boys,
        This is my first post in BADCAPS and I hope I don't make any mistakes and give the correct explanations.
        Yesterday a friend brought me this laptop home to expand the RAM to 16GB of RAM and update it since it had been abandoned recently.
        Everything was fine, until I made the mistake of updating the BIOS to version F.73 from version F.24, since after according to HP "updating correctly" the laptop never worked again, leaving the screen black but the fan is working and the light of M.2 is on.
        After having carried out all the frequent...
        10-15-2023, 07:31 AM
      • iZakre
        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
        by iZakre
        Hello everybody!
        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
        The thing is that I had installed TeamViewer and could log into the computer...
        02-19-2023, 02:27 PM
      • al3m0di
        Update bios EFCN58WW to EFCN59WW
        by al3m0di
        Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
        I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
        The BIOS version is EFCN58WW.
        When I turn on the device, it displays the message:
        "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
        The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
        I've tried
        07-29-2024, 10:32 AM
      • capoplays
        Help with BIOS update on Dell G15 5515 after chip replacement
        by capoplays
        Hey everyone,
        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
        When I check the BIOS using the F12 menu Flash...
        10-24-2025, 06:53 AM
