HP Elitebook 820 G2 bios needed
Re: HP Elitebook 820 G2 bios needed
Hi all. I am one of the peson that has been helped by Imranromi and would like to thank him.
By the way I would like to know what is the process of having the BIOS file cleaned up. Another member wrote me this...
"Ok real easy take your top half of your original file and merge it with the bottom half of either the update or donor file so let's say your bio's file is 8mb so the first 4mb merge to the other 4mb and you are done on most hp on newer ones pass words are stored in the kbc all doable just need the correct programmer to load the clean firmware and the last is the newer hex tool using disable code .
Techman1025"
... is that true?Comment
have you solved your problem.i have the same return error on a probook 450 G2 even with an unlocked mpm.Comment
Imranromi had the same problem as you,fixed by manually editing the DMI info . https://www.badcaps.net/forum/showth...t=52848&page=9Comment
SMDFlea,thanks for your answer,but i did before on another unit with success but this keeps returning the same message whatever i do."ME has been committed it can not be committed again Failed to commit Status = 80000000000007".this with uncommited state and mpm unlocked.Last edited by bachir2004; 10-16-2018, 08:07 AM.Comment
In most cases you need to pull the chip they sell a clip so no need to pull chip off but I never had to much luck with it. Need a programmer like the t860 A around 100. On eBay with the correct adapters read chip save a copy the upload in you case I think you model has to chips main bios &EC . So what’s the problem . Password.
Techman1025Comment
I have a tech question about BIOS manipulating. IAW the information I had from the forum it is quite easy to remove the password just merging the first half of the dump file with the second half of update/donor file. Fact is that I have a dump file that is 16 MB large and the original bin file from HP (let us say the N75 013 BIOS) that is a bin file 9 MB large.
That said, If I take half of dump file I'll have 8 MB, if I then take half of original BIOS I'll have 4,5 MB....so the total will be more or less - 12,5 MB - smaller than 16 MB but I see that the modified files are always 16 MB.
Is my understanding right or not?
Thank you for your help.Comment
The file you downloaded from web (9 mb file) does not go on start of 16mb file, it goes to the end. Open 9 mb file in hex editor and scroll untill you find bytes that are not 0x00h... open 16mb file also and search first few bytes from 9mb file and then overrite 16mb file with 9mb file. It must fit, it must not be bigger or smaller than 16mb qnd thats itIm Back... sort of...
Thank you for your kind and clear answer. I will try.
Time ago I contacted HP for support and I received the smc.bin file from HP but the proceure did not work.
I can provide the file to forum members for studying purposes if someone is interested.Comment
Thanks for the help. When i tried to write this file i got the following error "chip main memory with the contents are in disagreement" Screenshot is attached. Is it the file or am i doing something wrong?Attached Filesif you find these attachements useful please consider making a small donation to the site
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
Channel: BIOS Requests ONLY!
by vinaypundithI have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
So, I'm looking for a BIOS dump for this machine - a 16MB one....-
I badly need bios dump for HP DM1-4000er,
Model: HP DM1-4000er
Motherboard: DA0NM9MB6D0 REV.D
Product: QJ490EA#ACB
Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
- Loading...
