HP Elitebook 820 G2 bios needed
  • Marko2711
    • May 2016
    • 22
    • BIH
    #241
    Re: HP Elitebook 820 G2 bios needed
    Tnx
    • OKRPKCOMP
      • Dec 2020
      • 439
      • PAKISTAN
      #242
      Need bios repair hp 820 g2
      board id snickers-6050a2635701-mb-a02 (hstnn-i29c)
      serial 5cg5261109
      prodult h9w31et
      • pourvou3
        • Mar 2021
        • 11
        • maroc
        #243
        Need bios hp 820 g2
        board id PEVDH00WB9M1Y6
        serial 5CG5431VYG
        prodult F6N30AV
        MERCI
        • peste
          • 13728
          • ROMANIA
          #244
          Originally posted by pourvou3
          Need bios hp 820 g2
          serial 5CG5431VYG
          prodult F6N30AV
          MERCI
          always when you request a bios, also post the original bios even if it is corrupted
          • pourvou3
            • Mar 2021
            • 11
            • maroc
            #245
            Ok
            • hoaca388
              Badcaps
              • Jan 2022
              • 12406
              #246
              Ok
              HP EliteBook 820 G2 Base Model Notebook PC
              • pourvou3
                • Mar 2021
                • 11
                • maroc
                #247
                Thank you so much i will try and inform you
                • pourvou3
                  • Mar 2021
                  • 11
                  • maroc
                  #248
                  Thank you so much
                  • pourvou3
                    • Mar 2021
                    • 11
                    • maroc
                    #249
                    HI I have set the bios of the PC BUT the screen remains black and the fan is running at high speed
                    • pourvou3
                      • Mar 2021
                      • 11
                      • maroc
                      #250
                      • ymifdal
                        • Jan 2022
                        • 120
                        • Morocco
                        #251
                        try this one flashing the 128
                        I hope It'll work for you
                        • pourvou3
                          • Mar 2021
                          • 11
                          • maroc
                          #252
                          try this one flashing the 128??????
                          • ymifdal
                            • Jan 2022
                            • 120
                            • Morocco
                            #253
                            you made a backup of 2 different chips in the file you posted
                            only write what I sent you to the main bios chip
                            you named it "BIOSREDOUANE128.bin"
                            • pourvou3
                              • Mar 2021
                              • 11
                              • maroc
                              #254
                              OK THANKS MY FRIEND
                              • pourvou3
                                • Mar 2021
                                • 11
                                • maroc
                                #255
                                THANK YOU MY FRIEND it works but remains the problem of locked mpm
                                • ymifdal
                                  • Jan 2022
                                  • 120
                                  • Morocco
                                  #256
                                  Just update bios from official HP website to latest version
                                  If problem stays here for you https://youtu.be/9T57ktw8n3Y
                                  • pourvou3
                                    • Mar 2021
                                    • 11
                                    • maroc
                                    #257
                                    OK CHOUKRANE :réjouir:
                                    • jmfgm
                                      • Feb 2021
                                      • belgium
                                      #258
                                      HP EliteBook 820 G2 BIOS password
                                      Can anyone find out the Bios password from the eeprom W25Q128FV file attached?
                                      My programmer can only read the memory but cannot write the dump.
                                      Thanks.
                                      https://www.badcaps.net/forum/attach...1&d=1666292172
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12406
                                        #259
                                        Re: HP EliteBook 820 G2 BIOS password
                                        Thanks.
                                        Impossible.
                                        • Emifix
                                          • Mar 2021
                                          • 5
                                          • Nigeria
                                          #260
                                          Please I need 820 g2 unlocked bios bin file
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • TacticalFahrrad
                                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                            by TacticalFahrrad
                                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                            06-30-2025, 04:09 AM
                                          • vinaypundith
                                            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                            by vinaypundith
                                            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                            So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                            08-03-2024, 12:32 PM
                                          • James Maxwell
                                            HP DM1-4000er Bios Dump needed
                                            by James Maxwell
                                            I badly need bios dump for HP DM1-4000er,
                                            Model: HP DM1-4000er
                                            Motherboard: DA0NM9MB6D0 REV.D
                                            Product: QJ490EA#ACB
                                            Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                            10-28-2024, 05:38 PM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
