HP Elitebook 820 G2 bios needed
  • satdream
    • Jan 2017
    • 9
    • France
    #41
    Re: HP Elitebook 820 G2 bios needed
    Still the same issue with 1.29, 25Q128 in correct position.
    I plug the CH341A, then the detect works fine, and then ... no erasing or programming works. If I unplug/replug it works x1 time ... then redetect do not work a second time ...
    Do you have a link to the 1.29 release + driver you used to successfully program the 25Q128 ?
    Thanks !
    • bora_vr6
      • 12
      • Mexico
      #42
      Thanks !
      Try it again, but this time:
      1.- Disable any antivirus (your app or the Windows defender)
      2.- Try to unzip again your Programmer app, on the first times I use it, one file is detected like virus, and my antivirus automatically disable it (without notification), so after antivirus and firewall disabled, the programmer run properly.
      I hop this works for you, otherwise, let me found how can I upload or find the source link where I download.
      Regards
      • satdream
        • Jan 2017
        • 9
        • France
        #43
        finally changing programer I was able to manage the Winbond chipset.
        I successfully flashed EC+BIOS.bin on a 840 G2 (somebody kindly proposed here the 2 fulldump files)
        But I've an issue as the Elitebook start in MPM mode (Ok), but then detect issue "not in commited state", reset the bios and restore a config ... and I lost the MPM mode not able to get it back and use wmdmifit tool to enter UUID, SKU etc.
        Does somebody successfully recover MPM mode to configure an Elitebook ?
        Thanks !
        • peben
          • Mar 2017
          • 6
          • Netherlands
          #44
          Hello Satdream,
          I have a 840 G2 with bios password, and also have a ch341a programmer.
          I was wondering:
          you used a different hardware or software? And what hardware /software you used?
          Are those the files at post #4 of this topic?
          https://www.badcaps.net/forum/showpo...79&postcount=4
          But I've an issue as the Elitebook start in MPM mode (Ok), but then detect issue "not in commited state", ...
          after this warning, you reset the laptop (10 times) before booting to windows so you could use winmifit to alter sku/ serial etc..?
          hope you can help me out,
          with regards,
          Peben
          • satdream
            • Jan 2017
            • 9
            • France
            #45
            I finally ordered another SPI programmer (EZP2013) as with the CH341 I never successfully programmed the Windbond Q128.
            Yes
            No, after the warning, it was not possible to boot before the bios restored configuration (network etc.) and then the MPM mode was disabled before being able to boot WinME and run winmifit etc.
            Finally I got another Bios (here also) of 820 G2 (fully compatible with 840 G2), from somebody asked to clear password ... flashing with bios I got a fully workable laptop (no warning message etc.) BUT, I got also the SKU/Serial of the PC the Bios come from ... and not mine ...
            In any case for me the CH341 never worked for the main Bios chip, I tried several release of the software but once detected, then error to communicate ...)
            Hope this help
            • peben
              • Mar 2017
              • 6
              • Netherlands
              #46
              Re: HP Elitebook 850 G2 bios admin pwd help
              Hello Rioreno,
              Originally posted by rioreno
              -for programmer depending your budget, but if you dont have issue for budget , better you check for svod programmer...
              http://www.svod.od.ua/124-programmer-kb9012
              this svod programmer can be used for programming bios chips without desoldering it?
              regards,
              Peben
              • rioreno
                • Feb 2009
                • 540
                • Indonesia
                #47
                Hello Rioreno,
                regards,
                Peben
                I think this tool can used programming chip without desolder, you can use soicclip as a tool..
                • ardeyalex
                  Banned
                  • Feb 2014
                  • 36
                  #48
                  Can someone please help me?
                  I have a 820 g2 with no original bios dump and the post image appears after 20 seconds. I tried all dumps in this topic.
                  My laptop series are:
                  SN: 5CG53413XH
                  SKU: F6N29AV
                  PCID: A3009D510303
                  In Uefi tool i get the following errors:
                  Manny Thanks for anny solutions!
                  • satdream
                    • Jan 2017
                    • 9
                    • France
                    #49
                    SN: 5CG53413XH
                    SKU: F6N29AV
                    PCID: A3009D510303
                    The bios provided by RIORENO Page 4 is working and allow to boot and work reuglarly with correct SN/SKU etc. BUT you'll not be able to change them ...
                    try this..goodluck
                    • ardeyalex
                      Banned
                      • Feb 2014
                      • 36
                      #50
                      I tried this dump too, still 20 second until post image
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • Côte d'Ivoire
                        #51
                        try this
                        • ardeyalex
                          Banned
                          • Feb 2014
                          • 36
                          #52
                          Originally posted by dycc
                          try this
                          This works perfect, THANK YOU!!!
                          • fifthy52
                            • Oct 2014
                            • 11
                            • SK
                            #53
                            Hi DYCC
                            Can you explain what it means ME clear?
                            I have dump from post 4 in my elitebook too.
                            thx
                            • dycc
                              Vision
                              • Nov 2011
                              • 625
                              • Côte d'Ivoire
                              #54
                              Originally posted by fifthy52
                              Hi DYCC
                              thx
                              it mean add the original intel management engine release by INTEL into the bin file
                              • faisalali
                                • Mar 2016
                                • 25
                                • pakistan
                                #55
                                urgent need bios bin file 840 g2 plz help me out its very urgent thanks,
                                • abdulhalim933
                                  • Oct 2015
                                  • 14
                                  • damascus
                                  #56
                                  Here
                                  first of all thank you for your effort and does this bios work fine without password
                                  because i have hp 840 g2 with locked bios
                                  please tell me
                                  thank you
                                  • faisalali
                                    • Mar 2016
                                    • 25
                                    • pakistan
                                    #57
                                    hello, try this, if need to change sn, board id, use wndmifit or hpbcu..
                                    thanks its work
                                    • abdulhalim933
                                      • Oct 2015
                                      • 14
                                      • damascus
                                      #58
                                      Here
                                      can you unlock this for me
                                      beacaus i had a problem after reflashing 840 g2 bios that you uploded
                                      machine is not in commited state
                                      and still about 15 sec to appear post logo
                                      it'm may be because there is invalid sn or system board ct number
                                      please help me
                                      thank in advance
                                      • rioreno
                                        • Feb 2009
                                        • 540
                                        • Indonesia
                                        #59
                                        please help me
                                        thank in advance
                                        Try this..
                                        goodluck and please confirm..
                                        • abdulhalim933
                                          • Oct 2015
                                          • 14
                                          • damascus
                                          #60
                                          Try this..
                                          a hundreds of thanks for you
                                          it's worked correctly
                                          But i have the same problem with my lenovo l540
                                          it's take about 18 sec to appear post logo i tried a lot of bios dump but still the same problem can you help me with it
                                          thanks in advance
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • TacticalFahrrad
                                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                            by TacticalFahrrad
                                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                            06-30-2025, 04:09 AM
                                          • vinaypundith
                                            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                            by vinaypundith
                                            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                            So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                            08-03-2024, 12:32 PM
                                          • James Maxwell
                                            HP DM1-4000er Bios Dump needed
                                            by James Maxwell
                                            I badly need bios dump for HP DM1-4000er,
                                            Model: HP DM1-4000er
                                            Motherboard: DA0NM9MB6D0 REV.D
                                            Product: QJ490EA#ACB
                                            Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                            10-28-2024, 05:38 PM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
