Elitebook 8460P BIOS dump please
  • alihomee
    • Dec 2012
    • 1570
    • malaysia
    need bios file for this model.......its a intel mobo without any graphic
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: hp elitebook 8460p
    motherboard code or old dump?
    Im Back... sort of...
    • alihomee
      • Dec 2012
      • 1570
      • malaysia
      thanks ala....i got it and flashed.....now working fine
      • dj_ricoh
        • 2073
        Can you post it?
        • sasocoa
          • Mar 2013
          • bosna i hercegovina
          Not tested.
          • subroto
            • Oct 2015
            • 230
            • Bangladesh
            Please give me BIOS dump for Elitebook 8460P i5, UMA.
            • imranromi
              • Jan 2015
              • 1288
              • Pakistan
              Re: Elitebook 8460P BIOS dump please
              try this working.
              • subroto
                • Oct 2015
                • 230
                • Bangladesh
                Thanks Imran vai
                • imranromi
                  • Jan 2015
                  • 1288
                  • Pakistan
                  Hp 8460p intel Working dump
                  Working
                  • Nasir Raja
                    • Mar 2014
                    • 21
                    • United Kingdom
                    Cheerz mate also say thanks to admin bless
                    • bidawisoft
                      • Nov 2016
                      • 17
                      • morocco
                      thnx imranromi
                      • DProf.
                        • Jun 2018
                        • 97
                        • Nigeria
                        Bios dump for HP elitebook 8460p
                        Please I need a bios dump (file) for HP elitebook 8460p. 6050A2398501-MB-AO2 Can anyone help me out with it please.
                          • 20504
                          Re: Bios dump for HP elitebook 8460p
                          Use the Search . https://www.badcaps.net/forum/showthread.php?t=67599
                          • DeniS182
                            • Jun 2014
                            • 328
                            • Slovakia
                            HP 8460p bios fix
                            I'm in this section because of my thread : https://www.badcaps.net/forum/showthread.php?t=84702
                            Please can someone check my bios file, fix it , clean ME region or something witch can maybe help with my problem? Thanks!
                            • DeniS182
                              • Jun 2014
                              • 328
                              • Slovakia
                              Re: HP 8460p bios fix
                              something which...
                              I try clean ME region using Intel Easy Clean Me software. Laptop with this dump POST, but shutdown problem is still here. After 1-2 sec laptop turn off by itself.
                              • lapfix
                                • Mar 2020
                                • 2659
                                • my workshop
                                Different Firmware Repository beteween your 2 dumps !
                                Use Flash Image Tool better Than Intel Easy clean ME.
                                The firmware of your first bios is : 7.1.3.1053 ,SKU 5MB.
                                the second is : 7.1.10.1065 , SKU 1.5MB.
                                  • 20504
                                  Try this one .
                                  • DeniS182
                                    • Jun 2014
                                    • 328
                                    • Slovakia
                                    I try it. Laptop post but with some Message About bios update and problem is still here.
                                      • 20504
                                      2nd try
                                      • lap12
                                        • Mar 2019
                                        • 40
                                        hp 8460p
                                        i have HP 8460p where upon boot i get "wlan module id (702) wireless module not supported" error
                                        i try tp flash naother bios but the error is the same like before
                                        i think need file to remove whitelist for that model
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • Guest
                                          Elitebook 850 G5 BIOS bricked
                                          by Guest
                                          I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                          I assume the BIOS update failed, so I searched for the BIOS chip.
                                          I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                          However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                          Can the corrupted...
                                          03-24-2025, 01:21 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
                                        • DynaxSC
                                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                          by DynaxSC
                                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                          11-06-2022, 05:22 PM
