Elitebook 8460P BIOS dump please
  • alihomee
    • Dec 2012
    • 1596
    • malaysia
    need bios file for this model.......its a intel mobo without any graphic
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: hp elitebook 8460p
    motherboard code or old dump?
    Im Back... sort of...
    • alihomee
      • Dec 2012
      • 1596
      • malaysia
      thanks ala....i got it and flashed.....now working fine
      • dj_ricoh
        • 2073
        Can you post it?
        • sasocoa
          • Mar 2013
          • bosna i hercegovina
          Not tested.
          • subroto
            • Oct 2015
            • 230
            • Bangladesh
            Please give me BIOS dump for Elitebook 8460P i5, UMA.
            • imranromi
              • Jan 2015
              • 1290
              • Pakistan
              Re: Elitebook 8460P BIOS dump please
              try this working.
              • subroto
                • Oct 2015
                • 230
                • Bangladesh
                Thanks Imran vai
                • imranromi
                  • Jan 2015
                  • 1290
                  • Pakistan
                  Hp 8460p intel Working dump
                  Working
                  • Nasir Raja
                    • Mar 2014
                    • 21
                    • United Kingdom
                    Cheerz mate also say thanks to admin bless
                    • bidawisoft
                      • Nov 2016
                      • 17
                      • morocco
                      thnx imranromi
                      • DProf.
                        • Jun 2018
                        • 100
                        • Nigeria
                        Bios dump for HP elitebook 8460p
                        Please I need a bios dump (file) for HP elitebook 8460p. 6050A2398501-MB-AO2 Can anyone help me out with it please.
                          • 22146
                          Re: Bios dump for HP elitebook 8460p
                          Use the Search . https://www.badcaps.net/forum/showthread.php?t=67599
                          • DeniS182
                            • Jun 2014
                            • 328
                            • Slovakia
                            HP 8460p bios fix
                            I'm in this section because of my thread : https://www.badcaps.net/forum/showthread.php?t=84702
                            Please can someone check my bios file, fix it , clean ME region or something witch can maybe help with my problem? Thanks!
                            • DeniS182
                              • Jun 2014
                              • 328
                              • Slovakia
                              Re: HP 8460p bios fix
                              something which...
                              I try clean ME region using Intel Easy Clean Me software. Laptop with this dump POST, but shutdown problem is still here. After 1-2 sec laptop turn off by itself.
                              • lapfix
                                • Mar 2020
                                • 2765
                                • my workshop
                                Different Firmware Repository beteween your 2 dumps !
                                Use Flash Image Tool better Than Intel Easy clean ME.
                                The firmware of your first bios is : 7.1.3.1053 ,SKU 5MB.
                                the second is : 7.1.10.1065 , SKU 1.5MB.
                                  • 22146
                                  Try this one .
                                  • DeniS182
                                    • Jun 2014
                                    • 328
                                    • Slovakia
                                    I try it. Laptop post but with some Message About bios update and problem is still here.
                                      • 22146
                                      2nd try
                                      • lap12
                                        • Mar 2019
                                        • 40
                                        hp 8460p
                                        i have HP 8460p where upon boot i get "wlan module id (702) wireless module not supported" error
                                        i try tp flash naother bios but the error is the same like before
                                        i think need file to remove whitelist for that model
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
