Asus X42J bios dump
  • lezsimply
    The Wanderer
    • 659
    • Philippines
    Asus X42J bios dump
    Good day guys. Do you have bios dump for this laptop? Motherboard code is K42Jr rev 4.1. Laptop came to me with no power. Found out dc jack is busted so I replaced it and now laptop has power. When I press power button all lights are normal but there's no display on screen and external monitor. Tried multiple memory modules but same result.
    It seems that motherboard is reacting because when laptop it turned on, fan will not spin unless it reaches a certain temp. I think gpu would be less an issue here because owner mentioned it was working before power went out. Owner also mentioned laptop has not been used for over a year since it lost its power. Hope someone has. Thanks very much!
  • alihomee
    • Dec 2012
    • 1599
    • malaysia
    Re: Asus X42J bios dump
    try and post results
    • lezsimply
      The Wanderer
      • 659
      • Philippines
      ok I will try this alihomee. thanks. for the meantime, this is bios file extracted from chip.
      • lezsimply
        The Wanderer
        • 659
        • Philippines
        tried your file alihomee but still no go. I downloaded file from asus website and its smaller, only 2mb file. Dump extracted from chip is 4mb.
        • alihomee
          • Dec 2012
          • 1599
          • malaysia
          what is the problem
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            if this bios does not work, then its not bios related problem
            Im Back... sort of...
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              i think it was different file. if i look with HxD at address 3FF34C is K42JY (stock) and your file at address 3FF34C is K42JE. but i don't know...maybe different model and not working. just my opinion
              and ala_borbe was fix it
              • lezsimply
                The Wanderer
                • 659
                • Philippines
                ok I'll try ala's file. If it doesn't work, I'll do a mild reflow on gpu. I already checked all voltage and values are good.
                The owner mentioned that he was watching movie, then he moved laptop on a different location then suddenly it turned off. When I disassembled laptop I found dc jack broken, solder cracked from trace. I rebuild it then got the laptop to turn on. Thats why I'm considering the gpu as the least faulty one but not impossible. I'll update you asap guys. Thank you very much to all.
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  asus dc jack solder on motherboard often breaks.... i try to have 5-6 at hand at all times... often pad lifts, so you have to solder directly on coil or cap
                  • lezsimply
                    The Wanderer
                    • 659
                    • Philippines
                    Since the problem is no longer related to bios, I will close this thread and start a new one. Thanks for all the help!
                    • mwmakki
                      • Sep 2017
                      • 9
                      • Aleppo
                      Thank you very much for this file
                      • razu
                        • Jan 2015
                        • 218
                        • Bangladesh
                        Ala_borbe You r the genious.Your Bios File is 100% okkkkkkkkk .......Thanks for upload sir .............
                        • dqtech
                          Badcaps
                          • Jul 2018
                          • 641
                          • N/A
                          thanks a lot
                          • mkdj
                            by mkdj
                            Dear all,
                            10-19-2025, 04:41 AM
                          • razor_amd
                            by razor_amd
                            12-15-2020, 07:07 PM
                          • DynaxSC
                            by DynaxSC
                            06-14-2024, 03:49 PM
                          • Ahari
                            by Ahari
                            I...
                            08-13-2025, 06:12 AM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
