asus K52JR not starting. need 4MB bios rom
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3582
    • slovakia
    Have this asus k52jr that have some problems with 3.3v that loks like shorted. but after flash bios it came ok, but not starting. i measure that PM_PWRBTN# signal from ITE 8570 did not some but PWR_SW# did come to them. i think that ITE could be a problem but i can be even BIOS. Have somebody tested BIOS rom for K52JR with 4MB bios file?
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: asus K52JR not starting. need 4MB bios rom
    you can read your non-woking bios and i can fix it for you
    Im Back... sort of...
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3582
      • slovakia
      Here u go. Thanks for checking it
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        here you go
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3582
          • slovakia
          thx i will try
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3582
            • slovakia
            bios looks ok but laptop not starting. im missing PM_PWRBTN# from EC to PCH
            • FComp
              • Oct 2016
              • 16
              • Slovensko
              Hi
              Please help.
              I have a laptop K52F and K52F.
              After programming bios programmer through my notebook boots up fine, but I have a problem in that the CPU is overheating.
              After 10-30 sec. I turn off the notebook.
              There are still some special setup or BIOS CPU?
              Thank you very much
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                try this
                same bios only clean me region
                • FComp
                  • Oct 2016
                  • 16
                  • Slovensko
                  try this
                  Now does not start or BIOS.
                  The exact type of laptop is: A52F-SX627D
                  K52F motherboard is a rev 2.0
                  Thank you
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    Pls read and post your backup bios
                    the first and original one
                    • FComp
                      • Oct 2016
                      • 16
                      • Slovensko
                      I do not have original BIOS backup.
                      ASUS K52F 218.bin
                      This is a BIOS that neatly but the CPU is overheating. 30 seconds after the restart.
                      • FComp
                        • Oct 2016
                        • 16
                        • Slovensko
                        Is there any utility or program for editing bin file?
                        I would like to modify.
                        well thank you
                        • FComp
                          • Oct 2016
                          • 16
                          • Slovensko
                          well thank you
                          SST25VF032B - chip bios
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1488
                            • portugal
                            you have HEXEDITOR for editing the bin files.
                            Fcomp he asked for the bin file you got (new and your backup) , he dont need the bios code chip :P
                            • FComp
                              • Oct 2016
                              • 16
                              • Slovensko
                              Chip on board
                              A52F-SX627D_MB-K52F_rev2.0_ver.zip
                              I have now programmed this.
                              Everything works. The problem is LAN / can not run / error in the driver.
                              CPU still has 80 to 90 ° C fan is noisy around 4000 rpm.
                              But notebook is turned off or fall.
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1488
                                • portugal
                                seems to me bad cooler , and only after cooler replacement we will see if fan is still high , if still high , then bios must be with clean region
                                • khaahk
                                  • Dec 2013
                                  • 763
                                  • Estonia
                                  For LAN card to work you need to copy MAC address to new dump. MAC address is printed on a sticker on the mainboard, find it in the old dump in hex and replace. It should be there 2 times sequentially, change both of them.
                                  • FComp
                                    • Oct 2016
                                    • 16
                                    • Slovensko
                                    How do I clean bios region ?
                                    • FComp
                                      • Oct 2016
                                      • 16
                                      • Slovensko
                                      Lan it´s OK. Adding a MAC Address.
                                      Thanks you
                                      • khaahk
                                        • Dec 2013
                                        • 763
                                        • Estonia
                                        if the sticker is missing from mainboard then you are in trouble...
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
