Have this asus k52jr that have some problems with 3.3v that loks like shorted. but after flash bios it came ok, but not starting. i measure that PM_PWRBTN# signal from ITE 8570 did not some but PWR_SW# did come to them. i think that ITE could be a problem but i can be even BIOS. Have somebody tested BIOS rom for K52JR with 4MB bios file?
asus K52JR not starting. need 4MB bios rom
Tags: None
Re: asus K52JR not starting. need 4MB bios rom
Here u go. Thanks for checking itAttached Filesif you find these attachements useful please consider making a small donation to the site
here you goAttached Filesif you find these attachements useful please consider making a small donation to the site
Im Back... sort of...
bios looks ok but laptop not starting. im missing PM_PWRBTN# from EC to PCHComment
Hi
Please help.
I have a laptop K52F and K52F.
After programming bios programmer through my notebook boots up fine, but I have a problem in that the CPU is overheating.
After 10-30 sec. I turn off the notebook.
There are still some special setup or BIOS CPU?
Thank you very muchComment
try this
same bios only clean me regionAttached Filesif you find these attachements useful please consider making a small donation to the site
Chip on board
A52F-SX627D_MB-K52F_rev2.0_ver.zip
I have now programmed this.
Everything works. The problem is LAN / can not run / error in the driver.
CPU still has 80 to 90 ° C fan is noisy around 4000 rpm.
But notebook is turned off or fall.Attached Filesif you find these attachements useful please consider making a small donation to the site
For LAN card to work you need to copy MAC address to new dump. MAC address is printed on a sticker on the mainboard, find it in the old dump in hex and replace. It should be there 2 times sequentially, change both of them.Comment
Lan it´s OK. Adding a MAC Address.
Thanks youLast edited by FComp; 10-14-2016, 12:22 PM.Comment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by piratiHello everyone,
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
- Loading...
