does anyone has X551CA Bios dump ? laptop power gets to the first mosfet then nothing
  • Blacktek
    • Nov 2014
    • 250
    Could this be a bios issue? i took the bios out, try to read it and it says its BLANK, therefore my suspicion. x551ca rev 2.2. this is the bios i got from the website but its in .211 format and its too large when i try to use it
  • Blacktek
    • Nov 2014
    • 250
    Re: does anyone has X551CA Bios dump ? laptop power gets to the first mosfet then not
    bump
    • Blacktek
      • Nov 2014
      • 250
      bump
      • khaahk
        • Dec 2013
        • 766
        • Estonia
        Could be, from another forum:
        You might need to inject form old dump sn,mac,win key
        from address 21048d to 2330ff to this one.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3592
          • slovakia
          first two mosfets are driven by charging ic.
          • Blacktek
            • Nov 2014
            • 250
            good to know but i dont think im getting power on the charging ic, ill double check
            • Blacktek
              • Nov 2014
              • 250
              Thank you soo much my friends but you lost me at "You might need to inject form old dump sn,mac,win key
              from address 21048d to 2330ff to this one". AS MY OLD CHIP SAYS IS BLANK.
              Would this work if i use it just the way you sent it?
              • khaahk
                • Dec 2013
                • 766
                • Estonia
                Yes it should work without these numbers, but you might have windows license problems, network card problems...
                If old chip was all blank, then you have nothing to copy from there.
                • Blacktek
                  • Nov 2014
                  • 250
                  Im using CH341A programmer but it wont let me use this type of file, it says supported files are .Bin and .HEX
                  • techman1025
                    • Jun 2014
                    • 497
                    Hi
                    Yes fixable the only way is get a donor bios and rebuild the me region ...if you just use a donor fans will be full speed or reboots all caused by me region once a intel computer boots it's married to that computer ....not the case for amd plateform .
                    i could do it when i'm not so busy
                    techman1025
                    • techman1025
                      • Jun 2014
                      • 497
                      hi here is a new file if laptop boots then i will rebuild me region and you will be set to go.
                      Techman1025
                      • Blacktek
                        • Nov 2014
                        • 250
                        Techman1025
                        thanks a million techman2015..im going to try it out and ill keep you updated.
                        • Blacktek
                          • Nov 2014
                          • 250
                          I keep getting an error msg saying "write operations timeout failed"
                          • khaahk
                            • Dec 2013
                            • 766
                            • Estonia
                            Bad bios chip?
                            Bad contact with chip?
                            Bad programmer?
                            I am not familiar with this programmer software - does the chip get id-d correctly?
                            I have used many times dumps from donors without rebuilding the image.
                            • Blacktek
                              • Nov 2014
                              • 250
                              this chip is a Windbond 25Q64FVS1G but the software detects a 25Q64BV, this might be the reason why. Couldnt find it manually either.
                              Would you recommend a good software that is compatible with this programmer?
                              • khaahk
                                • Dec 2013
                                • 766
                                • Estonia
                                If it is a 25Q64FW - then it is 1.8V flash - then it needs an adapter.
                                Can not find an 25Q64FV datasheet...
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1488
                                  • portugal
                                  my friend , if voltage is not passing true first mosfet , then lift second mosfet , and inject 19 volts again and chek if you now got voltage on the outher side of the mosfet .. and also if gate voltage is correct . if so replace the mosfet you lifted and simply is fine to turn on .. alltough and one member sayed , first mosfet are controler by charger IC ,, so i believe you got a bad FET or could have something wrong with charger ic
                                  • highpulse
                                    i hate HP
                                    • May 2013
                                    • 1488
                                    • portugal
                                    alltough if you reading a dump that is empty could be causes due to incompatibility with your rom flasher (time to times you have to install new firmware for you hardware (it will also add new chips to the system read) i had problems with a few samsungs , bad reading etc etc , after firmware update , all good now
                                    but in any case if you bios is dead Techman is a great HEXA guy he will fix you this for sure .
                                    • Blacktek
                                      • Nov 2014
                                      • 250
                                      Thankx a bunch guys. I found two other boards with the 25Q64 bios chip, but i dont know if they are compatible. i got a 25Q64FWS1G from a Toshiba C55 and a 25Q64FVS1 from a dv6-7000.
                                      • Blacktek
                                        • Nov 2014
                                        • 250
                                        Can i use a different software for my hardware? If so which one, im using the CH341A programmer but it doesnt really work for all 24x,25x chips.
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
                                        • DynaxSC
                                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                          by DynaxSC
                                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                          11-06-2022, 05:22 PM
