Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
  • grimacelord
    • Jan 2017
    • 380
    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
    Motherboard model number: DA0PAMB46A1 REV: A
    Secondary motherboard model number: 0PAB
    SKU: 685K4UA
    Serial number is: 5CD3223BJP
    Recently reflashed this laptop with latest BIOS and once I figured out it had a RAM issue as well (see other thread I linked to above if you want more background info about this laptop) and the laptop finally booted normally, I was met with a message saying something along the lines of, "Motherboard is in manufacture programming mode" and none of the identifying numbers was entered in the BIOS such as model, serial number, prodID, etc.
    I was able to successfully set all of the relevant identification numbers for this model using HP's BIOS Configuration Utility (BCU), but I am stuck at the UUID part. I understand it can be retrieved from a BIOS dump and I tried looking through the dump in a hex editor, but I'm not sure where to look. I tried to search for obvious things like simply searching for "UUID" but that came up with no results. I think the UUID is supposed to be a 32 character string I just don't know how to find it in the BIOS dump with a hex editor and was hoping someone could help me out.
    Attached is original BIOS dump. Thank you!
  • grimacelord
    • Jan 2017
    • 380
    Derp. Nevermind. After actually writing all of the identification numbers to the BIOS using BCU tool, I suppose the UUID was generated because it is now listed correctly and everything is working fine.
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • haitham sharabati
      by haitham sharabati
      Hello engineers 😀,
      🔧 Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      💀 Problem:😅
      08-07-2025, 04:54 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • greelidd
      K6604J Vivobook RTX 4070 BIOS Dump Request
      by greelidd
      Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
      Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
      09-01-2025, 06:14 PM
