HP 14-dq0055dx - BIOS problem - "Pending Image Being Cleared" Loop
This topic has been answered.
  • grimacelord
    • Jan 2017
    • 380
    I have an HP 14-dq0055dx laptop here that came in for boot looping. It was previously taken to another shop and they tried flashing a BIOS firmware to the chip, so I cannot take an original dump. For a second or two, a message will come up on the screen that says:
    "The System BIOS Pending Image is being cleared.
    Do not shutdown or remove power from your computer during the clearing.
    The clear will take a few minutes to complete.
    For more information, please visit: (generic HP support website link)l
    Clearing Pending Image"
    This loop will go on for as long as you like. I let it run for about 12 hours and came in the following morning and it's still looping.
    Motherboard model number: DA0PAMB46A1 REV: A
    Secondary motherboard model number: 0PAB
    SKU: 685K4UA
    Attached is the latest BIOS download from HP's website for this model (sp150458.zip)
    Attached also is the BIOS dump I took before I tried flashing it myself (although this is not the original dump, as someone has already tried flashing this once before)
    I did try to flash this chip with a Xgpro T48/TL866II Plus programmer ​using the latest BIOS from HP myself, but it had no effect. The computer still loops like this. I am not skilled enough yet with working with BIOS files directly, so if someone could please take a look at this, I'd appreciate it very much.
  • Answer selected by grimacelord at 05-06-2024, 09:11 AM.
    grimacelord
    • Jan 2017
    • 380
    Wow. What a weird problem. It was the RAM. Replaced RAM with a different module and BIOS finished the "Pending Image" message and it has now booted into Windows. So it was never a BIOS/EC problem. It was RAM all along. Solved.
    • qayyum786
      • Aug 2018
      • 1958
      • INDIA
      SKU: 685K4UA
      When you extracted bios from EXE try 0864A and 0864D 1 by 1
      (on next or every new post include Serial Number as well)
      • grimacelord
        • Jan 2017
        • 380
        Oops! I meant to post serial number in original post, but must have forgot. Serial number is: 5CD3223BJP
        Flashing 0864A caused the computer to not power on whatsoever. No lights or anything
        Flashing 0864D​ returned the computer to the original boot loop problem with "Clearing Pending Image" message. Loops forever.
        • qayyum786
          • Aug 2018
          • 1958
          • INDIA
          Flashing 0864D returned the computer to the original boot loop problem with "Clearing Pending Image" message. Loops forever.
          Try this from hp support if this work for you
          https://h30434.www3.hp.com/t5/Notebo...k/td-p/8856668
          Step1. Turn off the Unit.
          2. Disconnect the AC adapter.
          3. Remove any discs from the disc drive.
          4. Remove memory cards from the card reader slot.
          5. Disconnect all nonessential peripheral devices, such as printers, scanners, external hard drives, and USB flash drives.
          6. Disconnect the AC adapter press and hold the power button for approximately 15 seconds.
          7. Reconnect the AC adapter, and then turn on the computer.
          Step 2 BIOS
          Turn off the unit and please press and hold the Windows key + letter B key and the power button together for 30 seconds after 30 seconds, 1st release the power button but keep holding the Windows key and B key for ten more seconds and then release these two keys If done correctly, you will see the display flashing once. Please attempt it thrice as this step and Restart the unit
          Step3
          The unit has to be turned off, Press Win+ V while holding these two keys then Press the Power button, continue to hold all three keys for 30 seconds and then release the Power button first and then release these two keys Please attempt it thrice and then you may get a Pop-Up CMOS Check and it will restart the unit
          Even if you don't get a Pop-up restart the unit manually after 3 attempts.
          Update the drivers
          • grimacelord
            • Jan 2017
            • 380
            Tried this and there was no effect. Computer did not respond to Win+B or Win+V methods. After trying both 3 times and seeing nothing happening, powered on the laptop manually and back to same boot loop
            • grimacelord
              • Jan 2017
              • 380
              Anyone have any ideas? I've flashed this BIOS chip with both BIOS images from the extracted .EXE and neither one of them fixes the problem. One BIOS image causes the computer to be completely unresponsive and the other has no effect at all. Could the BIOS chip itself be defective? I'm trying to understand what is happening here. If I'm erasing the BIOS chip and then flashing it with a new BIOS image, but the computer is still stuck on a looping "Clearing Pending Image" message, it seems to me like the BIOS chip itself could be faulty or another component on the board entirely such as the ITE/EC? Just trying to think of reasons why this continues to happen even after flashing a new image.
                • 21577
                Try an older version.
                • grimacelord
                  • Jan 2017
                  • 380
                  Thanks for the reply. Unfortunately, that BIOS image just causes a black screen, but does show power on LED and charging LED.
                    • 21577
                    Get all of the different bios versions from HP support and extract them, try all 0864D starting with the oldest first
                    • grimacelord
                      • Jan 2017
                      • 380
                      Tried every BIOS version from HP's website that contained an 0864D BIOS image. All produced the same loop or black screen/no LEDs. I even changed the BIOS chip itself with no effect.
                      Interestingly, when I open the original dump (or at least, the dump I took when it came to me as someone else tried to flash this before) in a hex editor and search for "0864", I find an entry that reads:
                      BID0864D F.26
                      The strange thing is, I cannot find a version F.26 for this model on HP's website. HP's website has the following:
                      F.08, F.21, F.33, and F.32. No mention of F.26...
                      • qayyum786
                        • Aug 2018
                        • 1958
                        • INDIA
                        flash your ec if programable i dont think so issue in main bios
                        • grimacelord
                          • Jan 2017
                          • 380
                          EC is ITE IT8887HE - Is this EC programmable?
                          • qayyum786
                            • Aug 2018
                            • 1958
                            • INDIA
                            yes it is
                            • grimacelord
                              • Jan 2017
                              • 380
                              yes it is
                              Thank you!
                              I do not have a dedicated EC programmer because I rarely need to program. I have Raspberry pi 3, XGemu Pro T48, CH341A, and a teensy. Can I use any of these to build my own EC programmer? I remember one time I ran jumper wires from the keyboard connector to the EC and flashed but I don't remember how I did it. That was years ago and has been the only time I have ever needed to flash the EC which is why I haven't bought an expensive programmer yet because I might need it once every 7 years.
                              • grimacelord
                                • Jan 2017
                                • 380
                                Also, I have an identical motherboard that doesn't work for other reasons, can I take the ITE chip from my broken motherboard and use it?
                                • grimacelord
                                  • Jan 2017
                                  • 380
                                  Does anyone know if I can take the ITE from an identical motherboard that doesn't work and use it to replace the ITE chip on this motherboard with the BIOS problem?
                                  • grimacelord
                                    • Jan 2017
                                    • 380
                                    Replacing ITE chip from identical motherboard had no effect. Still causes boot loop with "Pending Image Being Cleared"
                                    • grimacelord
                                      • Jan 2017
                                      • 380
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Facing exactly the same issue on HP 245 G7 hagrid20 6050a3178801-mb-a01.
                                        Flashed main +EC(IT8987E) from extracted bios from hp website(BID 085B1).
                                        Tried earlier versions,swapping 16MB eeprom chip(1.8V)-no result.
                                        changing the ram also didnt solve it.
                                        Win+B etc dont work.
                                        Any ideas??
                                        • grimacelord
                                          • Jan 2017
                                          • 380
                                          Any ideas??
                                          Sounds like you have already done everything I did except for change the EC chip itself from an identical motherboard.
                                          When I fixed mine, I flashed newest BIOS, replaced BIOS EEPROM, replaced ITE EC chip, and replaced the RAM module.
                                          I don't know if it was only replacing the RAM module that fixed it or a combination of several things I did, but since you've done everything else, try changing the EC from an identical scrap motherboard.
                                          • Focus2005
                                            HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                                            by Focus2005
                                            Hello everyone.
                                            I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                                            05-01-2025, 05:41 AM
                                          • kenkaniff
                                            HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                                            by kenkaniff
                                            Product Name: HP Pro x360 Fortis 11-inch G9
                                            System BIOS: U94 Ver.01.08.00 10/06/2023
                                            Serial Number: 5CG31946F5
                                            SKU Number: 85W05EC#AK8
                                            Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                                            This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                                            I needed to remove bios password...
                                            10-01-2025, 04:32 AM
                                          • DynaxSC
                                            by DynaxSC
                                            06-14-2024, 03:49 PM
                                          • Timeeez
                                            X270 - Bios flashing help
                                            by Timeeez
                                            I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
                                            Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
                                            11-30-2022, 05:17 PM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
