Could this be a bios issue? i took the bios out, try to read it and it says its BLANK, therefore my suspicion. x551ca rev 2.2. this is the bios i got from the website but its in .211 format and its too large when i try to use it
does anyone has X551CA Bios dump ? laptop power gets to the first mosfet then nothing
Re: does anyone has X551CA Bios dump ? laptop power gets to the first mosfet then not
Originally posted by khaahk View PostCould be, from another forum:
You might need to inject form old dump sn,mac,win key
from address 21048d to 2330ff to this one.
from address 21048d to 2330ff to this one". AS MY OLD CHIP SAYS IS BLANK.
Would this work if i use it just the way you sent it?
Originally posted by khaahk View PostYes it should work without these numbers, but you might have windows license problems, network card problems...
If old chip was all blank, then you have nothing to copy from there.
Hi
Yes fixable the only way is get a donor bios and rebuild the me region ...if you just use a donor fans will be full speed or reboots all caused by me region once a intel computer boots it's married to that computer ....not the case for amd plateform .
i could do it when i'm not so busy
techman1025
Originally posted by techman1025 View Posthi here is a new file if laptop boots then i will rebuild me region and you will be set to go.
Techman1025
Bad bios chip?
Bad contact with chip?
Bad programmer?
I am not familiar with this programmer software - does the chip get id-d correctly?
I have used many times dumps from donors without rebuilding the image.
this chip is a Windbond 25Q64FVS1G but the software detects a 25Q64BV, this might be the reason why. Couldnt find it manually either.
Would you recommend a good software that is compatible with this programmer?
my friend , if voltage is not passing true first mosfet , then lift second mosfet , and inject 19 volts again and chek if you now got voltage on the outher side of the mosfet .. and also if gate voltage is correct . if so replace the mosfet you lifted and simply is fine to turn on .. alltough and one member sayed , first mosfet are controler by charger IC ,, so i believe you got a bad FET or could have something wrong with charger ic
alltough if you reading a dump that is empty could be causes due to incompatibility with your rom flasher (time to times you have to install new firmware for you hardware (it will also add new chips to the system read) i had problems with a few samsungs , bad reading etc etc , after firmware update , all good now
but in any case if you bios is dead Techman is a great HEXA guy he will fix you this for sure .
Thankx a bunch guys. I found two other boards with the 25Q64 bios chip, but i dont know if they are compatible. i got a 25Q64FWS1G from a Toshiba C55 and a 25Q64FVS1 from a dv6-7000.Last edited by Blacktek; 08-18-2015, 11:04 AM.
Originally posted by highpulse View Postalltough if you reading a dump that is empty could be causes due to incompatibility with your rom flasher (time to times you have to install new firmware for you hardware (it will also add new chips to the system read) i had problems with a few samsungs , bad reading etc etc , after firmware update , all good now
