i Think it might be, but the sony website only gives you the executable file, which i cant use because i cant get into windows...any ideas how to get around this issue?
Sony SVF15, turns on no video...BIOS issue??
Re: Sony SVF15, turns on no video...BIOS issue??
install 7zip.
open the program, go to file and right click on the exe and select open inside.
then just go inside the director files and find the main bios file.
you will see it because even the program needs the raw biosJust cook it! It's already broken. -
The files dll, exe, ini, sys, scr are what comprise the Windows program to update the BIOS, the ROM file is the actual BIOS file. The next thing is to find a DOS executable program to flash the ROM file to the BIOS using a DOS bootable disk.
Hang on though, let me back up and ask why you think this is a BIOS problem? What steps have you taken to troubleshoot the issue? Tried connecting an external monitor for example?Last edited by SteveNielsen; 04-28-2015, 01:24 PM.Comment
https://www.badcaps.net/forum/showthread.php?t=1868The Night Drop Down, I Will Keep Try Until..., You Never know.
Dushi Kòrsou, Nos Tei.Comment
Well there is another problem you face, even if you had the means to update the BIOS from DOS if there is no video display how are you going to initiate the update flying blind?Comment
i have software called IDA pro and Hxd? i guess is worthless without the programmer..thanks a lot guys. Any tips on which programmer i should buy? brand name or should i be looking for something specific?Last edited by Blacktek; 04-28-2015, 02:16 PM.Comment
Sounds like it may be beyond the BIOS. Possibly a bad CPU chip or a bad chipset.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
http://www.ebay.co.uk/itm/24-25-Seri...item5d540aa2d6Comment
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by ahmedtouHi everyone,
help me please
I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
I will share all the details with you, including the disc information.
Code:HL-DT-ST BD-RE GGW-H20N XA02 (ATA) Current Profile: BD-R Disc Information: Status: Empty State of Last Session: Empty Erasable: No Free Sectors: 12,219,392 Free Space: 25,025,314,816 bytes Free Time: 2715:27:17 (MM:SS:FF) Next
by StephenHello, got a weird MacBook Air here
board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works... -
by cajoegHello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV... -
by AkuankaHi everyone,
I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78 showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
Thanks in advance for your help! - Loading...
