A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 676
    Hello, got a weird MacBook Air here
    board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works when you turn the computer on, but Safe Mode or normal OS loading it turns off completely. You can see the image still when you shine a light through it. Thanks
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • reformatt
    • Feb 2020
    • 1585
    Re: A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
    What is the backlight voltage on D7701 during fault condition? 8.6V or 0V? Also check BKL_EN and BKL_PWM during fault condition.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 676
      Will do thanks! I’ll post my readings
      sigpic
      • dellxps15
        • Feb 2014
        • 1600
        • italy
        check also lid sensor not being the problem.
        if u can renable backlight by moving mouse, power botton and it ask for login while u were on desktop before screen goes off, then it's lid sensor.
        • reformatt
          • Feb 2020
          • 1585
          Lid sensor is in the DC IN board, so just swap it out to test.
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 676
            Not the lid sensor already swapped that out with DC board. Ruled that out very quickly. Will be posting readings here later today
            sigpic
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 676
              0V for D7701
              sigpic
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 676
                No reading on BKL EN
                sigpic
                • mon2
                  • 15328
                  What is the 820-**** number of your logic board?
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 676
                    820-00165-a
                    sigpic
                    • mon2
                      • 15328
                      What is the voltage to ground of the following?
                      EDP_BKLT_EN
                      BKLT_PLT_RST_L
                      Each of these 2 mosfets must be ON, to create the voltage divider @ LCDBKLT_EN_DIV_L (gate) and then Q7706 will enable to enable the backlight.
                      • Stephen
                        Meow Meow MEOW!
                        • Apr 2020
                        • 676
                        EDP_BKLT_EN
                        0 VOLTS
                        BKLT_PLT_RST_L
                        3.3Volts
                        sigpic
                        • reformatt
                          • Feb 2020
                          • 1585
                          So it is definitely being disabled then. Do you see this problem in Recovery mode? Thinking it's a hardware issue triggered when the kext is loaded in the OS. Backlight enable is from the CPU, won't come on if a display is not detected. Have you tried another display per chance? Might be something screwy with the SMBUS connections perhaps.
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 676
                            Tried another board with this display it is using so not the display. It is definitely the board
                            sigpic
                            • Stephen
                              Meow Meow MEOW!
                              • Apr 2020
                              • 676
                              Recovery mode BACKLIGHT is on.
                              sigpic
                              • reformatt
                                • Feb 2020
                                • 1585
                                Seems to point to a graphics issue within the CPU (or bad solder ball). Is it a an Apple FRU board by chance? Have seen a few weird issues with those, especially if the CPU has been reworked.
                                Do you still have the PWM present when the backlight is disabled?
                                • kevingill
                                  • Jun 2013
                                  • 152
                                  • England
                                  Might be worth wiring EDP_BKLT_EN to 3.3v then?
                                  Bit of a bodge, but would get it working.
                                  • piernov
                                    • Jan 2016
                                    • 4438
                                    • France
                                    No SMC_LID measurements?
                                    • Stephen
                                      Meow Meow MEOW!
                                      • Apr 2020
                                      • 676
                                      I’ll get this looked at Monday. Simple fix I’m sure
                                      sigpic
