Sony SVF15, turns on no video...BIOS issue??
  • dj_ricoh
    • 2073
    • uk
    Re: Sony SVF15, turns on no video...BIOS issue??
    There is a adapter that goes inside and on the other side a clip that hooks on the ic 8 leg clip.
    • markopolo
      • Mar 2014
      • 27
      • Slovenia
      Do you still have the bios dump for svf15 DAoGD6MB8E0 I can't find it anywhere
      • sparker1
        • Sep 2011
        • 343
        I've been de-soldering and re soldering the chips every time and sometimes things have gone awry (with so called collateral damage)! I wish I knew about these adapters beforehand. Thanks for this info. I've just bought one and I'm now waiting for its arrival.
        • dj_ricoh
          • 2073
          • uk
          Check every wire.
          You may have to attach another wire for it to work.
          The wire its to cheap.
          • Blacktek
            • Nov 2014
            • 250
            Mine came in a week ago and i was already able to fix another sony laptop with it, I got it without a display when it was on. i wasnt so sucessful with 2 other laptops i tried to reprogram the bios chip. perhaps they have different issues. Very easy to do, the hardest part is finding these dumps.
            • m1ch43lzm
              by m1ch43lzm
              Hi everyone
              09-06-2025, 05:47 PM
            • ahmedtou
              HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
              by ahmedtou
              help me please
              I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
              When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
              I will share all the details with you, including the disc information.
              Code:
              HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
              Current Profile: BD-R
              Disc Information:
              Status: Empty
              State of Last Session: Empty
              Erasable: No
              Free Sectors: 12,219,392
              Free Space: 25,025,314,816 bytes
              Free Time: 2715:27:17 (MM:SS:FF)
              Next
              08-27-2025, 08:49 AM
            • Stephen
              A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
              by Stephen
              Hello, got a weird MacBook Air here
              board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
              08-23-2023, 09:12 AM
            • cajoeg
              Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
              by cajoeg
              Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
              The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
              02-10-2025, 04:01 PM
            • Akuanka
              Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
              by Akuanka
              I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
              Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
              Thanks in advance for your help!
              11-23-2024, 01:12 PM
