Asus tuf f15 fx507ZI
  • Tondo27
    • Aug 2024
    • 25
    • slovakia
    hello I am looking for new clean bios for the Asus fx507ZI laptop
    SN: R9NRKD050068376. thank you.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12281
    FX507ZI4
    • Tondo27
      • Aug 2024
      • 25
      • slovakia
      bios is not working properly. neither the lights nor the display show, only the keyboard lights up.
      • Tondo27
        • Aug 2024
        • 25
        • slovakia
        Hello, can someone fix the bios for my laptop? The laptop starts with another bios but not with mine. Thanks.
          • 21692
          post the working one.
          • Tondo27
            • Aug 2024
            • 25
            • slovakia
            This is the original bios that came with the laptop.
            Asus fx507ZI
            SN: R9NRKD050068376
            • Tondo27
              • Aug 2024
              • 25
              • slovakia
              and I used this bios which is higher.
              This one is functional but it tells me that I have to download the BIOS from Asus and flash it, I can't get into the BIOS menu.
              • m1ch43lzm
                • Mar 2019
                • 807
                • Peru
                Try version 329, replaced only BIOS region, ME region is the same from the "functional" BIOS
                FX507ZI4
                S/N R9NRKD050068376
                First boot may take some minutes
                IF you still get the message afterwards, follow the instructions in Scenario 2
                https://www.asus.com/support/faq/1040405/
                Download 329 version for EZ Flash and extract the file to the root directory of a USB drive formatted FAT32
                https://www.asus.com/supportonly/fx5...helpdesk_bios/
                • Tondo27
                  • Aug 2024
                  • 25
                  • slovakia
                  FX507ZI4
                  S/N R9NRKD050068376
                  With this bios the laptop starts but without a screen
                    • 21692
                    Scan the QR code on the motherboard and post what it says. If you can`t scan it post a good clear picture instead.
                    • Tondo27
                      • Aug 2024
                      • 25
                      • slovakia
                      I am attaching a photo of the motherboard. QR code
                        SMDFlea commented
                        Editing a comment
                        The model scanned from the QR is FX507ZI4. The bios posted by m1ch43lzm should be working, check your soldering and if you use a CH341A erase the chip first
                    • m1ch43lzm
                      • Mar 2019
                      • 807
                      • Peru
                      Try test2 BIOS, this has different ME version 16.1.25.1865
                      Power on, wait for several minutes
                      If if doesnt work try test3, ME version 16.1.30.2330
                      FX507ZI4
                      • Tondo27
                        • Aug 2024
                        • 25
                        • slovakia
                        it works strangely in both test 2 and test 3, the fans turn on but without a picture, after a while the laptop restarts, it does this 3 times and then only the charging light remains on.
                        • m1ch43lzm
                          • Mar 2019
                          • 807
                          • Peru
                          Does the laptop react to power button after it powers off? Try this: after you only get charging light, unplug charger, unplug battery, plug in battery and charger, press power button
                          If that doesn't work, try again with the BIOS which shows a screen with the message to download from ASUS website, then try the BIOS recovery method on post 8 from the link on ASUS website
                          • Tondo27
                            • Aug 2024
                            • 25
                            • slovakia
                            yes, the button responds normally, but only with the charger, the laptop cannot be turned on without the charger. I wondered if the ITE 5571VG could still be damaged. I tried to update the bios using USB, but it doesn't respond, it just says bios recovery.
                            • m1ch43lzm
                              • Mar 2019
                              • 807
                              • Peru
                              Read the BIOS chip in it's current state, upload the backup
                              The ME region should be initialized now, I want to try replacing the BIOS region on it keeping the same ME region
                              • Tondo27
                                • Aug 2024
                                • 25
                                • slovakia
                                I am attaching the BIOS that triggered the BIOS recovery. It was read from the chip.
                                • m1ch43lzm
                                  • Mar 2019
                                  • 807
                                  • Peru
                                  Try, replaced BIOS region from FX507ZI4 329 + DMI
                                  • Tondo27
                                    • Aug 2024
                                    • 25
                                    • slovakia
                                    bios still same behavior without image. but what I find out on the right is very strange, according to the measurement, the board has no short circuit, all the values ​seem to be correct. the behavior is that the laptop cannot be turned on via the battery, nor via USB C. only via the charger, but the battery is not charged via this, only via usb c and even that only at 0.3A. as soon as I disconnect the charger when it is on, the device turns off after a second. I tried to change the charging IC but the behavior is still the same.I think that the EC ITE CHIP might be faulty
                                    • razor_amd
                                      by razor_amd
                                      12-15-2020, 07:07 PM
                                    • grimacelord
                                      by grimacelord
                                      07-10-2025, 02:52 PM
                                    • throwaway327
                                      by throwaway327
                                      Model No: RC72LA
                                      Serial No: SBNVKD001014459
                                      06-18-2025, 05:52 PM
                                    • lrouw84
                                      by lrouw84
                                      Hi there,
                                      01-28-2023, 01:31 PM
                                    • ferah831208
                                      help with bios decompose for Asus s5506ma
                                      by ferah831208
                                      I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
                                      08-24-2025, 05:35 PM
