Asus tuf f15 fx507ZI
  • Tondo27
    • Aug 2024
    • 21
    • slovakia
    hello I am looking for new clean bios for the Asus fx507ZI laptop
    SN: R9NRKD050068376. thank you.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12118
    FX507ZI4
    • Tondo27
      • Aug 2024
      • 21
      • slovakia
      bios is not working properly. neither the lights nor the display show, only the keyboard lights up.
      • Tondo27
        • Aug 2024
        • 21
        • slovakia
        Hello, can someone fix the bios for my laptop? The laptop starts with another bios but not with mine. Thanks.
          • 21466
          post the working one.
          • Tondo27
            • Aug 2024
            • 21
            • slovakia
            This is the original bios that came with the laptop.
            Asus fx507ZI
            SN: R9NRKD050068376
            • Tondo27
              • Aug 2024
              • 21
              • slovakia
              and I used this bios which is higher.
              This one is functional but it tells me that I have to download the BIOS from Asus and flash it, I can't get into the BIOS menu.
              • m1ch43lzm
                • Mar 2019
                • 634
                • Peru
                Try version 329, replaced only BIOS region, ME region is the same from the "functional" BIOS
                FX507ZI4
                S/N R9NRKD050068376
                First boot may take some minutes
                IF you still get the message afterwards, follow the instructions in Scenario 2
                https://www.asus.com/support/faq/1040405/
                Download 329 version for EZ Flash and extract the file to the root directory of a USB drive formatted FAT32
                https://www.asus.com/supportonly/fx5...helpdesk_bios/
                • Tondo27
                  • Aug 2024
                  • 21
                  • slovakia
                  FX507ZI4
                  S/N R9NRKD050068376
                  With this bios the laptop starts but without a screen
                    • 21466
                    Scan the QR code on the motherboard and post what it says. If you can`t scan it post a good clear picture instead.
                    • Tondo27
                      • Aug 2024
                      • 21
                      • slovakia
                      I am attaching a photo of the motherboard. QR code
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • grimacelord
                        by grimacelord
                        07-10-2025, 02:52 PM
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • lrouw84
                        by lrouw84
                        Hi there,
                        01-28-2023, 01:31 PM
                      • ferah831208
                        help with bios decompose for Asus s5506ma
                        by ferah831208
                        I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
                        08-24-2025, 05:35 PM
