help with bios decompose for Asus s5506ma
  • ferah831208
    • Aug 2019
    • 65
    • Cuba
    I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that I can find the module I believe could be bios REGION, but I would have to use the first 30 percent of bios image from original bios dumped(where flash descriptor for example should be) because I cannot find the way to separate this image in modules. And my concern is original bios image might have data corruption in different modules. Does anyone have any info about this or recommend some method or utility I can use? thanks in advance and sorry maybe for my ignorance 😔
  • ferah831208
    • Aug 2019
    • 65
    • Cuba
    Update on this topic, I found that I can decompose this model bios image with mfit v18 I downloaded a link from winraid, now I have decomposed modules, and I can replace bios region with original Asus file downloaded from Asus server after decomposing that file with amipfatextractor. My question remains the same, I cannot find anyway to find out what was the original version of ME so I can replace the csme engine region for a cleaned one or at least for one that is not corrupted, anyone have info
    • hoaca388
      Badcaps
      • Jan 2022
      • 12257
      With ME 18 you will not get anything on Me analyzer
      ​https://www.badcaps.net/donate
      • ferah831208
        • Aug 2019
        • 65
        • Cuba
        Is there any extra tool or procedure to work with corresponding mfit I can consult?? Thanks in advance
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • oragano
          ASUS ex-b250-V7 motherboard bios corrupted - by me
          by oragano
          hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
          So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
          i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
          10-17-2024, 02:53 AM
