ASUS TUF DASH F15 FX517ZE-HN002W BIOS
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Attached FilesComment
It turns on with minhdigital bios, goes in windows, but NVIDIA error 43 in device manager. I have seen it again in Asus same story but could not find a way to fix it. Any idea how to solve it? Maybe bios needs some kind of special config? EC reflash? Although I have SVOD4, I did not find a config for this model in the software.
Thank you for your effort!Comment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
Hi All,
Laptop: ASUS F15 TUF Dash FX517ZC-HN114W
Context: When I was out the house my partner hard shutdown laptop while BIOS was updating, so my son has no working laptop now. Also as a result I know the BIOS on the chip is messed up so I can’t extract it using the ch341a and use it to perform the method explained on site to modify an update downloaded from the ASUS website to get the BIN to flash.
If anyone can help with a BIOS BIN/ROM file for this laptop, I would be forever in your debt! Thanks if you can help!
Assuming it is less than 2MB as...-
- Loading...
