ASUS TUF DASH F15 FX517ZE-HN002W BIOS
  • volinakis
    • Jan 2021
    • 2876
    • N/A
    Originally posted by tech_guru
    I found a dump for FX517ZE (attached). Laptop turns on and bios gets updated normally, but once the system boots and the nvidia driver gets installed, the laptop hangs and fans spin so I guess it only needs to clean the ME. Because also the ME analyzer says it has configuration so it's dirty. Can you clean it or show me a guide please? It is 16.0.15.1735.
    Thank you.
    your file has a clean ME ...
Name:	Screen Shot 2025-06-25 at 12.45.34.png
    • tech_guru
      • Nov 2018
      • 44
      • Greece
      Oh, then what does the bios need. I feel pretty sure it's the bios issue. Does it need to have all the dmi data from the original maybe?
      • volinakis
        • Jan 2021
        • 2876
        • N/A
        hoaca388 file should work, if not it means you have a hardware issue.
        • minhdigital
          • Nov 2022
          • 766
          • Vietnam
          Send to you
          • tech_guru
            • Nov 2018
            • 44
            • Greece
            Originally posted by minhdigital
            Send to you
            It turns on with minhdigital bios, goes in windows, but NVIDIA error 43 in device manager. I have seen it again in Asus same story but could not find a way to fix it. Any idea how to solve it? Maybe bios needs some kind of special config? EC reflash? Although I have SVOD4, I did not find a config for this model in the software.
            Thank you for your effort!
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
