ASUS TUF DASH F15 FX517ZE-HN002W BIOS
  • tech_guru
    • Nov 2018
    • 44
    • Greece
    Hello.
    Could you please repair the attached bios or send a new one to unbrick this laptop? It does not give image and the problem is the bios for sure because when i tried flashing a file from internet, it turns on but does not detect nvme disks and stucks.
    Motherboard: DA0NJLMBAD0 REV D NJL
    S/N: N3NRCX07N13211A
    CN: K46K
    MFD: 2022-03
    Thank you in advance
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Originally posted by tech_guru
    Hello.
    CN: K46K
    MFD: 2022-03
    FX517ZE
    • tech_guru
      • Nov 2018
      • 44
      • Greece
      Originally posted by hoaca388
      FX517ZE
      no image unfortunately
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        Post QR code on mainboard.
        • tech_guru
          • Nov 2018
          • 44
          • Greece
          There you go, thank you!
          • hoaca388
            Badcaps
            • Jan 2022
            • 12441
            • tech_guru
              • Nov 2018
              • 44
              • Greece
              Sorry for that, i think you want the one on the board, i also attach one on the cooler. Let me know if its wrong again
              • hoaca388
                Badcaps
                • Jan 2022
                • 12441
                Check hardware.
                • tech_guru
                  • Nov 2018
                  • 44
                  • Greece
                  Check hardware.
                  hardware is working. when i flash a dump i found online it turns on normally but either nvme does not work or usbs or it hangs in windows login.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12441
                    Post that file .
                    • tech_guru
                      • Nov 2018
                      • 44
                      • Greece
                      Post that file .
                      Thank you for your time
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12441
                        FX517ZE
                        • tech_guru
                          • Nov 2018
                          • 44
                          • Greece
                          FX517ZE
                          Same, leds turn on but no image. I flashed the one i sent you that i told you it works just to make sure again and it turned on. Attached photos. But when it goes to login screen it hangs, usbs turn off, no mouse+trackpad and the fans spin quickly after 1 minute. Also, if I try to update the bios via ez flash inside the bios, it does not accept FX517ZE bios, because the dump is from FX517ZC.
                          It starts to get difficult as I understand... Can't we make one from the original dump and the official one from the site or something?
                          I appreciate your time and efforts! Thank you so much
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12441
                            FX517ZC
                            • tech_guru
                              • Nov 2018
                              • 44
                              • Greece
                              same....
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12441
                                same....
                                Try flashing EC.
                                • tech_guru
                                  • Nov 2018
                                  • 44
                                  • Greece
                                  Try flashing EC.
                                  Flash it, and which bios should i have flashed in the bios chip together? The one you sent me in the beginning?
                                  Is it possible it is the ec problem since it turns on with the ZC bios?
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12441
                                    # 12 , ZE
                                    • tech_guru
                                      • Nov 2018
                                      • 44
                                      • Greece
                                      # 12 , ZE
                                      In SVOD4 I have i can't find an EC file a pinout available so I guess I am stuck there...
                                      Anyway, thank you for your time and effort!
                                      If any other idea pops out of any user, please let me know!
                                      • tech_guru
                                        • Nov 2018
                                        • 44
                                        • Greece
                                        # 12 , ZE
                                        I found a dump for FX517ZE (attached). Laptop turns on and bios gets updated normally, but once the system boots and the nvidia driver gets installed, the laptop hangs and fans spin so I guess it only needs to clean the ME. Because also the ME analyzer says it has configuration so it's dirty. Can you clean it or show me a guide please? It is 16.0.15.1735.
                                        Thank you.
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
