Thinkpad L13 Yoga Gen 4 - BIOS request
  • Alknik
    • Aug 2015
    • 14
    • Greece
    I have desoldered the 25R256JWEQ​ and read it with CH341.
    Can someone check it?
    • hoaca388
      Badcaps
      • Jan 2022
      • 12006
      Originally posted by Alknik
      I have desoldered the 25R256JWEQ and read it with CH341.
      L13 Yoga Gen 4 Laptop (ThinkPad) - Type 21FR
      Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------
      • Alknik
        • Aug 2015
        • 14
        • Greece
        Hi Hoaca338,
        I get no charging light and the laptop can not be turned on.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12006
          Hi Hoaca338,
          Check solder.
          • Alknik
            • Aug 2015
            • 14
            • Greece
            Check solder.
            Hi Hoaca388,
            I have checked the soldering of 25R256JWEQ and it seems to be ok.
            What should I do with W25Q128JNSQ ?
            Should I leave the original BIOS inside?
            With the original BIOS the pc would not boot and would not charge.
            When I used the OF_W25Q128JW1.8V@SOIC8.BIN BIOS from Alegoff, the laptop could charge and it could power on but the ESC,F1, F4 lights were blinking.
            Afterwards, I tried to flash other BIOS dumps to the same chip and from that point on, the Laptop could not be charged.
            Even if I dump OF_W25Q128JW1.8V@SOIC8.BIN again, there is no charging light.
            (Till now I have not desoldered the W25Q128JNSQ since I can read and write to the chip with the SOIC8 clip).
            As a reminder, the first time this issue happened was because of a failed BIOS update from Lenovo as described in the first post.
            How should I proceed?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12006
              #26
              Hi Hoaca388,
              Dump W25Q128JNSQ , post here.
              • Alknik
                • Aug 2015
                • 14
                • Greece
                #27
                I have attached the dump of W25Q128JNSQ.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12006
                  #28
                  Try
                  • Alknik
                    • Aug 2015
                    • 14
                    • Greece
                    #29
                    Try
                    Hi Hoaca388,
                    I still get no charging light and the laptop can not boot.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12006
                      #30
                      Hi Hoaca388,
                      Give up
                      • Prono113
                        • Jan 2020
                        • 41
                        • Vietnam
                        #31
                        Thinkpad l13 Gen 4\
                        Model: 21FQ-S2CB00
                        SN: PW-09A16X
                        Type C detect 5v but can't open 19v
                        I TRY https://www.badcaps.net/forum/troubl...4-bios-request BUT NOTTHING..
                        • peste
                          peste commented
                          Editing a comment
                          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                      • rumpumpel1
                        • Jul 2019
                        • 158
                        • germany
                        #32
                        I have a dead L13 Yoga Gen 4 AMD and my last hope is a defective Software.
                        From the EC I extracted the following data: MTM = 21FSS0W900, System-SN = PW0C14XC and the board-SN is W3CG45G049E.
                        Attached is the (eventually defective) SPI-ROM (32MB) and the EC-ROM (16MB).
                        • peste
                          peste commented
                          Editing a comment
                      • rumpumpel1
                        • Jul 2019
                        • 158
                        • germany
                        #33
                        @peste: most headlines do not distinguish between Intel and AMD versions, although the BIOS SW and related problems are completely different.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12006
                          #34
                          L13 Yoga Gen 4 Laptop (ThinkPad) - Type 21FS
                          • rumpumpel1
                            • Jul 2019
                            • 158
                            • germany
                            #35
                            thank you for your contribution.
                            In the meantime I was able to fix the laptop.
                            Symptoms were: completely dead, the board draw 70 mA at 5 V on both ports. No LED, no fan.
                            I downloaded from Lenovo the latest BIOS update and extracted from the archive the file $0AR2600.FL2 and pasted the file into my L13-Yoga_223002-1_EC-ROM.bin.
                            After having flashed the EC-ROM (W25Q128JW) with this image the laptop was working again.
                            • beogeek
                              • Apr 2018
                              • 100
                              • Serbia
                              #36
                              Can you explain what you mean by "pasted the file into my L13-Yoga_223002-1_EC-ROM.bin." what exactly did you do?
                              • rumpumpel1
                                • Jul 2019
                                • 158
                                • germany
                                #37
                                I meant "I flashed the file ..."
                                • beogeek
                                  • Apr 2018
                                  • 100
                                  • Serbia
                                  #38
                                  Can you upload the file if you still have it? I downloaded it from Lenovo and the file $0AR2600.FL2 is only 292KB... Can you confirm you used the same one and which bios ic did you flash it to? The BIOS 1 or BIOS 2 on the board. Cheers
                                  • rumpumpel1
                                    • Jul 2019
                                    • 158
                                    • germany
                                    #39
                                    you are confusing the BIOS and the EC-ROM.
                                    The BIOS Update package from Lenovo contains a file called *.FL1. It contains the EC-ROM. In order to generate a flashable image for the EC-ROM you need to cut off the first 32 bytes from the FL1-file and then expand it to the desired size with 0xFF.
                                    The BIOS Update package from Lenovo contains also a FL2-file. This contains portions of the BIOS but it is not sufficient to generate a flashable image for the BIOS.
                                    • Loki_Fido
                                      Thinkpad X1 Yoga Gen 3 ,How to know if the BIOS is corrupted
                                      by Loki_Fido
                                      Hi everyone, hope everyone's having a great day.
                                      I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
                                      I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
                                      So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
                                      Does this mean the BIOS is fine? making it a hardware issue?
                                      I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...
                                      03-14-2025, 07:42 PM
                                    • lucaszmn
                                      by lucaszmn
                                      Problem:
                                      Initial Findings:
                                      • I concluded that the
                                      08-12-2025, 03:01 PM
                                    • Maxpower3
                                      Brand name and Model Type for Lenovo error 2202 product name is invalid
                                      by Maxpower3
                                      Info for error 2202 LenovoThinkPad models and type
                                      Extract from ThinkPad Maintenance Utilities Configuration File
                                      plnsrv.ini Version 1.01
                                      Some information that may be useful
                                      There must also be missing models, add them to the list if you know of any.
                                      Code:
                                      brand name
                                      20B1=ThinkPad Edge E445
                                      20B2=ThinkPad Edge E545
                                      20BC=ThinkPad Edge E145
                                      20BM=ThinkPad X140e
                                      20BL=ThinkPad X140e
                                      20A3=ThinkPad X230s
                                      20AH=ThinkPad X230s
                                      20AK=ThinkPad X240s
                                      20AJ=ThinkPad X240s
                                      02-21-2024, 10:27 AM
                                    • beogeek
                                      Lenovo Yoga Slim 7 14APU8 Bios Request
                                      by beogeek
                                      I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                                      Attached is the bios dump in the state I received it...
                                      10-24-2024, 12:54 PM
                                    • akwky
                                      by akwky
                                      Hi!
                                      04-14-2025, 01:56 PM
