Thinkpad L13 Yoga Gen 4 - BIOS request
  • Alknik
    • Aug 2015
    • 14
    • Greece
    I have desoldered the 25R256JWEQ​ and read it with CH341.
    Can someone check it?
    • hoaca388
      Badcaps
      • Jan 2022
      • 11741
      Originally posted by Alknik
      I have desoldered the 25R256JWEQ and read it with CH341.
      L13 Yoga Gen 4 Laptop (ThinkPad) - Type 21FR
      • Alknik
        • Aug 2015
        • 14
        • Greece
        Hi Hoaca338,
        I get no charging light and the laptop can not be turned on.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11741
          Hi Hoaca338,
          Check solder.
          • Alknik
            • Aug 2015
            • 14
            • Greece
            Check solder.
            Hi Hoaca388,
            I have checked the soldering of 25R256JWEQ and it seems to be ok.
            What should I do with W25Q128JNSQ ?
            Should I leave the original BIOS inside?
            With the original BIOS the pc would not boot and would not charge.
            When I used the OF_W25Q128JW1.8V@SOIC8.BIN BIOS from Alegoff, the laptop could charge and it could power on but the ESC,F1, F4 lights were blinking.
            Afterwards, I tried to flash other BIOS dumps to the same chip and from that point on, the Laptop could not be charged.
            Even if I dump OF_W25Q128JW1.8V@SOIC8.BIN again, there is no charging light.
            (Till now I have not desoldered the W25Q128JNSQ since I can read and write to the chip with the SOIC8 clip).
            As a reminder, the first time this issue happened was because of a failed BIOS update from Lenovo as described in the first post.
            How should I proceed?
            • hoaca388
              Badcaps
              • Jan 2022
              • 11741
              #26
              Hi Hoaca388,
              Dump W25Q128JNSQ , post here.
              • Alknik
                • Aug 2015
                • 14
                • Greece
                #27
                I have attached the dump of W25Q128JNSQ.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11741
                  #28
                  Try
                  • Alknik
                    • Aug 2015
                    • 14
                    • Greece
                    #29
                    Try
                    Hi Hoaca388,
                    I still get no charging light and the laptop can not boot.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11741
                      #30
                      Hi Hoaca388,
                      Give up
                      • Prono113
                        • Jan 2020
                        • 41
                        • Vietnam
                        #31
                        Thinkpad l13 Gen 4\
                        Model: 21FQ-S2CB00
                        SN: PW-09A16X
                        Type C detect 5v but can't open 19v
                        I TRY https://www.badcaps.net/forum/troubl...4-bios-request BUT NOTTHING..
                        • peste
                          peste commented
                          Editing a comment
                          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                      • rumpumpel1
                        • Jul 2019
                        • 149
                        • germany
                        #32
                        I have a dead L13 Yoga Gen 4 AMD and my last hope is a defective Software.
                        From the EC I extracted the following data: MTM = 21FSS0W900, System-SN = PW0C14XC and the board-SN is W3CG45G049E.
                        Attached is the (eventually defective) SPI-ROM (32MB) and the EC-ROM (16MB).
                        • peste
                          peste commented
                          Editing a comment
                      • rumpumpel1
                        • Jul 2019
                        • 149
                        • germany
                        #33
                        @peste: most headlines do not distinguish between Intel and AMD versions, although the BIOS SW and related problems are completely different.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11741
                          #34
                          L13 Yoga Gen 4 Laptop (ThinkPad) - Type 21FS
                          • rumpumpel1
                            • Jul 2019
                            • 149
                            • germany
                            #35
                            thank you for your contribution.
                            In the meantime I was able to fix the laptop.
                            Symptoms were: completely dead, the board draw 70 mA at 5 V on both ports. No LED, no fan.
                            I downloaded from Lenovo the latest BIOS update and extracted from the archive the file $0AR2600.FL2 and pasted the file into my L13-Yoga_223002-1_EC-ROM.bin.
                            After having flashed the EC-ROM (W25Q128JW) with this image the laptop was working again.
                            • kitor
                              • Apr 2019
                              • 45
                              • Poland
                              #36
                              L13 G4, AMD - 21FQ-S04R00 / PW-067ZHK
                              Powers on, no image. Fans do spin when heated up, power button long press works to shut down and then press to start unit again.
                              No keyboard led blinking (except just a normal 1sec ESC/F1/F4 leds right after power button press).
                              What I already tried:
                              - extracted Lenovo update. .FL2 file contains EC image that appears twice in EC dump (similar to Yoga variant described here), i replaced both. No change in behaviour
                              - Truncated .FL1 file from the extra header and cut down to BIOS flash size (comparing in hex editor data aligns perfectly). Also no change. But possibly some sections of the original needs to be transferred over?
                              After flashing one extracted from .FL1 and failed boot I dumped BIOS again and saw differences so machine is definitely executing code...
                              Thermal imaging shows nothing suspicious.
                              Original BIOS dump when put into UefiTool complains about "not a single Volume Top File is found, image may be corrupted".
                              One extracted from .FL1 file parsed fine.
                              I attached both dumps (16M EC and 32M bios).
                              • peste
                                peste commented
                                Editing a comment
                            • Loki_Fido
                              Thinkpad X1 Yoga Gen 3 ,How to know if the BIOS is corrupted
                              by Loki_Fido
                              Hi everyone, hope everyone's having a great day.
                              I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
                              I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
                              So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
                              Does this mean the BIOS is fine? making it a hardware issue?
                              I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...
                              03-14-2025, 07:42 PM
                            • Maxpower3
                              Brand name and Model Type for Lenovo error 2202 product name is invalid
                              by Maxpower3
                              Info for error 2202 LenovoThinkPad models and type
                              Extract from ThinkPad Maintenance Utilities Configuration File
                              plnsrv.ini Version 1.01
                              Some information that may be useful
                              There must also be missing models, add them to the list if you know of any.
                              Code:
                              brand name
                              20B1=ThinkPad Edge E445
                              20B2=ThinkPad Edge E545
                              20BC=ThinkPad Edge E145
                              20BM=ThinkPad X140e
                              20BL=ThinkPad X140e
                              20A3=ThinkPad X230s
                              20AH=ThinkPad X230s
                              20AK=ThinkPad X240s
                              20AJ=ThinkPad X240s
                              02-21-2024, 10:27 AM
                            • beogeek
                              Lenovo Yoga Slim 7 14APU8 Bios Request
                              by beogeek
                              I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                              Attached is the bios dump in the state I received it...
                              10-24-2024, 12:54 PM
                            • akwky
                              by akwky
                              Hi!
                              04-14-2025, 01:56 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
