Dell 8FC8 Patcher
  • 0ldtime
    • Sep 2025
    • DE
    #121
    Thank you, for the Patcher. He saved my Laptop. Dell Latitude 5420.
    • twist522
      • Jul 2025
      • 3
      • Ukraine
      #122
      so grateful to you for this patcher! I could successfully unlock the dell3440 I bought locked! the chip I patched was xmc 25rh256cxin, I used ch341b which appeared to not require 5-3.3v mod as it showed to me 3.3v on all data pins. The chip was low profile wson8 so I had to use hot air gun and solder it right on the back of my ch341b. I used NeoProgrammer V2.2.0.10 with selected configuration for chip W25Q256FV as per https://www.badcaps.net/forum/troubl...49#post3171449
      A few tips for soldering first-timers:
      Be careful with hot air - as I was using hot air gun for the first time I put too much air as the board was dissipating warm and I messed up my board a couple of times blowing a few small resistors away. Fortunately I was able to put it back to life while changing one small resistor and fixing one of the traces. Put more temperature but less air (~30-40%) and keep warming up the area it may take up to few minutes if you're not using pre-heating table or something.
      • dryan433
        • Oct 2025
        • England
        #123
        Big thumbs up to the writer of this program did the trick as every other method failed i even didnt need to remove wson8 chip just programed it still on motherboard with a t48 programmer thanks once again 😀😀😀😀😀😎😎
        • tony.nicole
          • Feb 2025
          • France
          #124
          Hello from France, I can't find how to post a message on the site, because I'm looking for the password for the Dell Optiplex 7010 bios code C4RKHZ3 - 8FC8 of my son's computer to change the more efficient SSD, thank you.
          • peste
            • Dec 2016
            • 13768
            • ROMANIA
            #125
            post S/T, full name and model, motherboard model,etc.
            post the contents of the bios chip ....
            The bios chip must be unsoldered from the board before writing or reading..
            do not use the clip, you may have errors..if you do not have anything to unsolder it with,
            solder wires between the programmer and the bios chip..
            you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
            • Funky.Monk3y
              • Aug 2025
              • Deutschland
              #126
              I'm afraid I need the help of the professionals here.
              I tried to reset the BIOS password on my sister's notebook using the 8FC8 patcher. After successfully patching the BIN file, I had the chip soldered back in. Unfortunately, the notebook no longer shows any response (no charging LED or anything else).
              I would now try to install a clean BIOS on the chip instead of the patched one.
              But before I do that, it would be really great if someone could take a look at the clean BIN file, or maybe one of you already has a working BIOS-BIN file for the device.
              In the appendix, I have included the original image, the patched image from the 8FCF patcher, and the clean image I created myself.
              Notebook: Dell Latitude 5440
              Mainboard: LA-M401P
              Rev: 1.0(A00)
              Date: 2022-12-26
              ST: 14W9D24
              Any help is gratefully welcomed.
              • peste
                • Dec 2016
                • 13768
                • ROMANIA
                #127
                Mainboard: LA-M401P
                Rev: 1.0(A00)
                Date: 2022-12-26
                ST: 14W9D24
                check the solder joints, check the power supply to the bios chip...
                • harrygr
                  • Jan 2024
                  • Netherlands
                  #128
                  Fixed a Dell Latitude 3410 with this fantastic tool!
                  • Funky.Monk3y
                    • Aug 2025
                    • Deutschland
                    #129
                    I had the solder joints re-soldered by a professional who had also done all the soldering work at the beginning.
                    Unfortunately, there is no response from the notebook, except that the LED lights up amber when you press the start button.
                    • Markus1741
                      • Sep 2020
                      • 967
                      • N/A
                      #130
                      Hello, I had the same problem.
                      It is very important that the WSON 8 BIOS chip is soldered correctly again; the orange blinking indicates that the BIOS is not being addressed.
                      • Stefan Steff
                        • Mar 2024
                        • 380
                        • Romania
                        #131
                        I wish to add to this very good comment, that I encountered a lot of times MX25LXXX (MXP) WSON8 chips being damaged by heat.
                        So try replace the chip with a Winbond W25QXXX (check if it's in your VSCC table...)
                        • Bios White
                          Learn
                          • Dec 2024
                          • 88
                          • East Laos
                          #132
                          Check if it is in the VSCC table using which software, can you guide me in detail? Thank you.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12422
                            #133
                            UEFI Tool Ne alpha
                            ​https://www.badcaps.net/donate
                            • Bios White
                              Learn
                              • Dec 2024
                              • 88
                              • East Laos
                              #134
                              Originally posted by hoaca388
                              UEFI Tool Ne alpha
                              Flash chips in VSCC table:
                              C22019 (Macronix MX25L256)
                              EF4019 (Winbond W25Q256)
                              C84019 (GigaDevice GD25x256C)
                              Many thank
                              • lolo130
                                • Nov 2025
                                • 5
                                thank yoou i wish to know how to use it to unlock my device
                                  • 22130
                                  Drag and drop, see post 2.
                                  • simshady
                                    • Jun 2023
                                    Is it possible to use an intel FPT dump to do the unlock on a latitude 5440? 9P4JFY3-8FC8 fpt bios and me regions attached
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12422
                                      #138
                                      Read #1
                                      • simshady
                                        • Jun 2023
                                        Read #1
                                        I ended up doing some more research and I ended up finding some info which allowed me to successfully use this utility without any need for an external programmer. Schematics for my device documented a service mode (separate from the audio chip FD override), accessible by shorting ME_SW_PCH to 3.3V, which temporarily deactivates all spi protections. This allowed me to do a full read of my chip via flashrom, patch it, and reflash via FPT. Just figured I'd document this to help out those who have had issues with physical programmers. If anyone wants to try this and needs help finding the right test points feel free to pm me with your schematic and boardview.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                          Dell 8FC8 Bios Password Patcher
                                          by SMDFlea
                                            DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
                                            The unlock scripts given here are for personal use only, ie. you accidentally set a password on
                                            your own machine,you forgot the password you set a long time ago or you mistyped the password
                                            when setting it and cannot get in again.
                                            DISCLAIMER: THE SCRIPTS
                                          11-03-2023, 06:02 AM
                                        • al_b0sni
                                          Dell Optiplex 5000 8fc8 with chip W25Q128JVSN
                                          by al_b0sni
                                          Hey, i bought a Dell Optiplex 5000 8fc8 with chip W25Q128JVSN.
                                          I also used the CH341A programmer but my usb cable (i didnt attach it directly into the pc, i used a cable between) was corrupted. So i made a dump. Then i removed the password but unfortunately the dump had a loose contact so it was corrupted. And i've also overwrited the chip and now i dont have any dump anymore.
                                          Can someone help me? I am stuck since hours and i cannot find any bin file anywhere.
                                          I tried to extract the EXE for BIOS installation from dell and also the rcv file but i didn't manage to do that....
                                          06-18-2025, 03:42 PM
                                        • Livewire07
                                          Need Bios Dell Precision 7760 8FC8
                                          by Livewire07
                                          Please need Help to unlock this Bios. 8FC8
                                          Dell Precision 7760
                                          S/T 99XX2M3
                                          Much appreciated
                                          Yesterday, 04:54 PM
                                        • dr_crx
                                          Dell 7740 Bios locked J3JSD43-8FC8
                                          by dr_crx
                                          Hello i need help please
                                          i have DELL 7740 ST: J3JSD43-8FC8
                                          i tried to read bios bit i think it is wrong because the size of the file is around 1mb
                                          anyone can help to show its location on motherboard please.
                                          i attached the results file the IC i read is : winbond 25q80dvsig
                                          i don't know if its the needed bios or another bios on the motherboard.
                                          thank you in advanced for your help...
                                          07-11-2025, 12:22 AM
