Dell 8FC8 Patcher
  • 0ldtime
    • Sep 2025
    • DE
    #121
    Thank you, for the Patcher. He saved my Laptop. Dell Latitude 5420.
    • twist522
      • Jul 2025
      • 3
      • Ukraine
      #122
      so grateful to you for this patcher! I could successfully unlock the dell3440 I bought locked! the chip I patched was xmc 25rh256cxin, I used ch341b which appeared to not require 5-3.3v mod as it showed to me 3.3v on all data pins. The chip was low profile wson8 so I had to use hot air gun and solder it right on the back of my ch341b. I used NeoProgrammer V2.2.0.10 with selected configuration for chip W25Q256FV as per https://www.badcaps.net/forum/troubl...49#post3171449
      A few tips for soldering first-timers:
      Be careful with hot air - as I was using hot air gun for the first time I put too much air as the board was dissipating warm and I messed up my board a couple of times blowing a few small resistors away. Fortunately I was able to put it back to life while changing one small resistor and fixing one of the traces. Put more temperature but less air (~30-40%) and keep warming up the area it may take up to few minutes if you're not using pre-heating table or something.
        Dell 8FC8 Bios Password Patcher
        by SMDFlea
          DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
          The unlock scripts given here are for personal use only, ie. you accidentally set a password on
          your own machine,you forgot the password you set a long time ago or you mistyped the password
          when setting it and cannot get in again.
          DISCLAIMER: THE SCRIPTS
        11-03-2023, 06:02 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • al_b0sni
        Dell Optiplex 5000 8fc8 with chip W25Q128JVSN
        by al_b0sni
        Hey, i bought a Dell Optiplex 5000 8fc8 with chip W25Q128JVSN.
        I also used the CH341A programmer but my usb cable (i didnt attach it directly into the pc, i used a cable between) was corrupted. So i made a dump. Then i removed the password but unfortunately the dump had a loose contact so it was corrupted. And i've also overwrited the chip and now i dont have any dump anymore.
        Can someone help me? I am stuck since hours and i cannot find any bin file anywhere.
        I tried to extract the EXE for BIOS installation from dell and also the rcv file but i didn't manage to do that....
        06-18-2025, 03:42 PM
      • dr_crx
        Dell 7740 Bios locked J3JSD43-8FC8
        by dr_crx
        Hello i need help please
        i have DELL 7740 ST: J3JSD43-8FC8
        i tried to read bios bit i think it is wrong because the size of the file is around 1mb
        anyone can help to show its location on motherboard please.
        i attached the results file the IC i read is : winbond 25q80dvsig
        i don't know if its the needed bios or another bios on the motherboard.
        thank you in advanced for your help...
        07-11-2025, 12:22 AM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
