Bios dump need for lenovo ideapad 1 15ALC7
  • lngcs
    • Jul 2011
    • 72
    Hi, could some one please help extract or provide bios dump for Lenovo ideapad1 15alc7, MTM:8244007aau,s/n:pf4k2bzn.thanks
    • 21980
    https://www.badcaps.net/forum/troubl...40#post3307240 .Make a backup first, copy your DMI from your backup to the new bios using a hex editor with the offsets 1000 - 2FFF
    • lngcs
      • Jul 2011
      • 72
      Thank you for you help.
      • EdwinC
        • Aug 2022
        • Ecuador
        Can someone help me program this bios
        Model: IdeaPad 1 15ALC7
        S/N: JVHFC1
        • peste
          • Dec 2016
          • 13656
          • ROMANIA
          S/N: JVHFC1
          you have everything you need at post #7...
          https://www.badcaps.net/forum/troubl...a7#post3307240
          • rogafufuken
            • Mar 2023
            • Tapachula
            Hello everyone, it may seem like a novice but I can't find the Rom Bios, the one I unsoldered with the data that is silkscreened on the component does not appear any information on the internet and when unsoldering it and placing it in the CH431A or the EZP2019 + it does not detect it at all not even with the 1.8V volt adapter, could you tell me if I am choosing the correct component, I have looked for the Schematic but I can't find it either, it is a JS471 / JS573 Lenovo 15ALC7 Motherboard
              • 21980
              When the chip isn`t in the support list choose a different one for example W25Q128JW
              • NGABOY
                • Jul 2025
                • 0
                • Spain
                I used the EZP2019 and the ch341A Buy it keeps giving me an error, i tried everything but nothing worked, even the crisis recovery.
                • peste
                  • Dec 2016
                  • 13656
                  • ROMANIA
                  The bios chip must be unsoldered from the board before writing or reading..
                  do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                  solder wires between the programmer and the bios chip..
                  here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                  • Artuha
                    • Mar 2018
                    • 31
                    • Latvia
                    Hi everyone!
                    I have Lenovo IdeaPad 1 15ALC7 (NM-E541) with no power, board have only LDO 3V and 5V. No EC_ON_5VALW_R from EC (IT8227VG-256CX). If I erase EC controller firmware then got 1.8V and 5V, after that EC get it's firmware from main BIOS and again "no life" on board. May be anyone can help found out the reason?
                    Main board: NM-E541
                    S/N: PF4RAVW7
                    Device is out of warranty, because was liquid damaged.
                    Need to know what is necessary for EC to bring EC_ON_5VALW_R ON
                    main BIOS dump attached.
                      SMDFlea commented
                      Editing a comment
                      Thread merged. Read post #2 ,just copy your DMI to the new bios using a hex editor, copy/paste
                  • Artuha
                    • Mar 2018
                    • 31
                    • Latvia
                    Tried this, without success, still no EC_ON_5VALW_R
                      SMDFlea commented
                      Editing a comment
                      probably a bad EC chip
                  • GabyCR
                    • Mar 2015
                    • 31
                    • España
                    I have this laptop with a GD25LR128. Not available on TL866II.
                    someone can help me?? Maybe choosen another ic?? Or I’m wrong and this is not the Bios ic??
                    Thank you
                    • peste
                      • Dec 2016
                      • 13656
                      • ROMANIA
                      Thank you
                      you can manually choose an equivalent chip...
                      • m1ch43lzm
                        • Mar 2019
                        • 962
                        • Peru
                        Thank you
                        Try selecting GD25LQ128C/D/E
                        • m1ch43lzm
                          • Mar 2019
                          • 962
                          • Peru
                          Originally posted by Artuha
                          Hi everyone!
                          Main board: NM-E541
                          S/N: PF4RAVW7
                          Try EC firmware extracted from your BIOS, cut to 256KB, as far as I know EC can self program only on Intel models (not on AMD)
                          Also attached EC firmware extracted from latest BIOS version JTCN60WW
                          • madjid911
                            • Dec 2016
                            • 412
                            • France
                            Hello, could you please repair my original BIOS? I have all the correct voltages, but the laptop boots without displaying anything. I tried a BIOS here, but it didn't work; the Num Lock key remains lit.
                            LENOVO IDEAPPAD 1 15ALC7 (NM-E541)
                            SN: PF3RLN53
                            • peste
                              • Dec 2016
                              • 13656
                              • ROMANIA
                              SN: PF3RLN53
                              try post #5....
                              • m1ch43lzm
                                • Mar 2019
                                • 962
                                • Peru
                                Try
                                IdeaPad 1 15ALC7 Laptop - Type 82R4
                                BIOS ver JTCN60WW
                                S/N PF3RLN53
                                MTM 82R4009KFR
                                DMI 1000-2FFF
                                • madjid911
                                  • Dec 2016
                                  • 412
                                  • France
                                  Originally posted by m1ch43lzm
                                  Try
                                  BIOS ver JTCN60WW
                                  S/N PF3RLN53
                                  MTM 82R4009KFR
                                  DMI 1000-2FFF
                                  That didn't work, probably the SIO chip's program, but I don't know how to reprogram that kind of chip, thanks
                                  • mkdj
                                    Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                    by mkdj
                                    Dear all,
                                    I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                    Here the steps I have taken to fix the laptop:
                                    - downloaded latest BIOS from Lenovo Website...
                                    10-18-2025, 03:43 AM
                                  • jendkkd jeje
                                    Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                    by jendkkd jeje
                                    So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                    I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                    10-11-2024, 03:12 PM
                                  • joven016
                                    Lenovo Ideapad S145 need working bios HELP!!
                                    by joven016
                                    Problem is blinking power led only
                                    i don't know exactly if it's s145-15igm or s145-14igm
                                    have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                    Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                    Already tested some of posted bios here
                                    S145-14igm - success but invalid serial and not booting on OS
                                    S145-15igm - success with serial and some other info in bios but still not booting on OS
                                    already tried installing new windows but always booting on bios setup
                                    windows installer flash drive detected on...
                                    08-21-2025, 10:55 PM
                                  • AHmad_Salal
                                    Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                    by AHmad_Salal
                                    Hello all,
                                    I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                    11-28-2023, 05:28 AM
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
