Hi, could some one please help extract or provide bios dump for Lenovo ideapad1 15alc7, MTM:8244007aau,s/n:pf4k2bzn.thanks
Bios dump need for lenovo ideapad 1 15ALC7
Can someone help me program this bios
Model: IdeaPad 1 15ALC7
S/N: JVHFC1
Attached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
Hello everyone, it may seem like a novice but I can't find the Rom Bios, the one I unsoldered with the data that is silkscreened on the component does not appear any information on the internet and when unsoldering it and placing it in the CH431A or the EZP2019 + it does not detect it at all not even with the 1.8V volt adapter, could you tell me if I am choosing the correct component, I have looked for the Schematic but I can't find it either, it is a JS471 / JS573 Lenovo 15ALC7 Motherboard
Hello everyone, it may seem like a novice but I can't find the Rom Bios, the one I unsoldered with the data that is silkscreened on the component does not appear any information on the internet and when unsoldering it and placing it in the CH431A or the EZP2019 + it does not detect it at all not even with the 1.8V volt adapter, could you tell me if I am choosing the correct component, I have looked for the Schematic but I can't find it either, it is a JS471 / JS573 Lenovo 15ALC7 MotherboardComment
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
Channel: BIOS Requests ONLY!
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by AHmad_SalalHello all,
I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....-
by hirensLenovo ideapad 3 14IGL05 bios dump needed
model: 81wh
sn: pf36ta6h
board no: nm-c961 gs453/gs553
hey guys above is my laptop info
it only blinks the power button kindly help me with a working dump
old dump attached...-
by bob113313Hi,
first of all my apologies for my English (I don't speak it very well, I am French).
I am trying to troubleshoot a lenovo ideapad 5 15alc05 ryzen 7 that boots but remains in black screen.
I would like to know if anyone knows how to extract the .bin of bios from the exe published on the lenovo site. I have found several information on the internet but they don't work in my case. I think it's because it's an amd.
I found some dump on the internet but I don't really trust it. I would like to make a clean bis from the official Lenovo file...-
- Loading...
