Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
This topic has been answered.
  • mkdj
    • Mar 2025
    • 56
    • France
    Dear all,
    I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
    Here the steps I have taken to fix the laptop:
    - downloaded latest BIOS from Lenovo Website
    - followed the steps of this guide to create the BIOS.bin file https://www.badcaps.net/forum/troubl...k-bios?t=80861
    - copied DMI from the back-up to the new file with an Hex editor following advice on this post : https://winraid.level1techs.com/t/so...corrupt/111335
    - flashed the BIOS using Neo Programmer
    Any advice on the origin of this fault and how to fix it?
    Regards,
    mkdj
  • Answer selected by mkdj at 10-30-2025, 04:51 AM.
    mkdj
    • Mar 2025
    • 56
    • France
    Thank you for your message. I solved my problem. I was not using the right SSD for testing purposes. I am not familiar yet with the different technologies of SSD, interface, protcols, etc. I only used SSD with keys B+M to test the laptop (probably with SATA interface). Then I tried a SSD with only a M key (probably NVMe), and the disk got recognized.
    • mkdj
      • Mar 2025
      • 56
      • France
      Dear all,
      Update: I have tried flashing another older BIOS, found on this link: https://www.badcaps.net/forum/troubl...=4#post1605508
      I got the same result: laptop boots but Hard Disk Not Installed.
      I will try tomorrow to clean the M2 slot and do a visual inspection, even though I doubt it is an hardware issue (what are the odds that there is a BIOS and a hardware issue at the same time?)
      I will keep you updated. In the meantime, if you have an idea to unstuck me, I am interested.
      Regards,
      mkdj
      • ianbak
        • Apr 2023
        • 63
        I once had exactly the same problem with a Lenovo and it was because the BIOS I'd flashed wasn't quite the right one for the motherboard. Often a single Lenovo model can use two different motherboards, depending on when it was built. For instance, an L13 Yoga can be of Type 20R5 or Type 20R6. Check very carefully whether the BIOS you have used was the correct one for the specific motherboard you have.
        • mkdj
          • Mar 2025
          • 56
          • France
          • Deniz
            IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
            by Deniz
            Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
            I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
            I had the BIOS cleaned, but the issue was not resolved and there was still no image.
            Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
            After that, I tried to update the...
            01-27-2026, 06:56 AM
          • Do_Yuri
            Lenovo IdeaPad 3 15ADA05 (81W1) — cannot enter BIOS, system always boots in Legacy mode
            by Do_Yuri
            Hello.
            I’m trying to diagnose a Lenovo IdeaPad 3 15ADA05 (Model 81W1).
            Hardware
            Model: Lenovo IdeaPad 3 15ADA05 (81W1)
            BIOS version: E8CN34WW
            Internal drive: NVMe SSD (detected normally)
            Symptoms
            BIOS Setup is almost impossible to enter.
            Pressing F2 during power-on usually freezes on the Lenovo logo or is ignored.
            The Novo button opens the Novo Menu, but selecting BIOS Setup...
            08-01-2026, 01:58 PM
          • anton brunner
            Having a hard time dumping BIOS - Lenovo Ideapad Duet 3 (11IAN8)
            by anton brunner
            I'm having a hard time dumping the BIOS of a Lenovo Ideapad Duet 3 (11IAN8). The chip is a Winbond W25R256JVEN, directly soldered to the board in a WSON8 package.
            Since there are lots of tiny components near the chip, I was hesitant to desolder it using hot air. Instead, I soldered thin wires directly to the chip's pads and connected them to a CH341A programmer (photos attached).
            The chip is detected correctly in both NeoProgrammer and ASProgrammer, but I'm unable to get a consistent dump. I've tried over 15 times — shortened the wires to...
            05-15-2025, 01:01 AM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • federalhouse
            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
            by federalhouse
            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
            **Background:**
            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
            **What I've Tried So Far:**
            1. I accessed
            08-01-2024, 07:03 PM
