Bios dump need for lenovo ideapad 1 15ALC7
  • lngcs
    • Jul 2011
    • 69
    Hi, could some one please help extract or provide bios dump for Lenovo ideapad1 15alc7, MTM:8244007aau,s/n:pf4k2bzn.thanks
    • 21106
    https://www.badcaps.net/forum/troubl...40#post3307240 .Make a backup first, copy your DMI from your backup to the new bios using a hex editor with the offsets 1000 - 2FFF
    • lngcs
      • Jul 2011
      • 69
      Thank you for you help.
      • EdwinC
        • Aug 2022
        • Ecuador
        Can someone help me program this bios
        Model: IdeaPad 1 15ALC7
        S/N: JVHFC1
        • peste
          • Dec 2016
          • 12908
          • ROMANIA
          S/N: JVHFC1
          you have everything you need at post #7...
          https://www.badcaps.net/forum/troubl...a7#post3307240
          • rogafufuken
            • Mar 2023
            • Tapachula
            Hello everyone, it may seem like a novice but I can't find the Rom Bios, the one I unsoldered with the data that is silkscreened on the component does not appear any information on the internet and when unsoldering it and placing it in the CH431A or the EZP2019 + it does not detect it at all not even with the 1.8V volt adapter, could you tell me if I am choosing the correct component, I have looked for the Schematic but I can't find it either, it is a JS471 / JS573 Lenovo 15ALC7 Motherboard
              • 21106
              When the chip isn`t in the support list choose a different one for example W25Q128JW
              • NGABOY
                • Jul 2025
                • 0
                • Spain
                I used the EZP2019 and the ch341A Buy it keeps giving me an error, i tried everything but nothing worked, even the crisis recovery.
                • peste
                  • Dec 2016
                  • 12908
                  • ROMANIA
                  The bios chip must be unsoldered from the board before writing or reading..
                  do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                  solder wires between the programmer and the bios chip..
                  here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                  • jendkkd jeje
                    Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                    by jendkkd jeje
                    So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                    I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                    10-11-2024, 03:12 PM
                  • AHmad_Salal
                    Need BIOS Dump/ROM for Lenovo Thinkstation p500
                    by AHmad_Salal
                    Hello all,
                    I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                    11-28-2023, 05:28 AM
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mximiliandz
                    help bios lenovo ideapad s145-14iil type 81w6
                    by mximiliandz
                    Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                    06-20-2025, 06:50 AM
                  • hirens
                    Lenovo ideapad 3 14IGL05 bios dump needed
                    by hirens
                    model: 81wh
                    sn: pf36ta6h
                    board no: nm-c961 gs453/gs553
                    hey guys above is my laptop info
                    it only blinks the power button kindly help me with a working dump
                    old dump attached...
                    07-21-2023, 04:48 AM
