HP 14-dv1629na BIOS request. Motherboard DA0G7GMB8F0 REV.F
  • Darren Hibbert
    • 116
    Hi.
    I'm looking for the Bios Bin file to reflash my bios.
    Thanks.
    • 22109
    Originally posted by Darren Hibbert
    Hi.
    Thanks.
    Post your bios backup and laptop serial number,as per the rules https://www.badcaps.net/forum/troubl...before-posting
    Read Vesko`s HP guides to ID your bios BID
    7. Extracting BIOS/EC firmware from update packages
    https://www.badcaps.net/forum/troubl...=8#post1622426
    7.2.4. HP
    [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948 and
    [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
    • Darren Hibbert
      • 116
      Sorry, my mistake. Will get the serial number a bit later.
        • 22109
        No problem.Post your backup and someone will help
        • Darren Hibbert
          • 116
          HP 14-dv1629na model number.
          Serial Number - 5CD1466KB9
          Laptop turns on and off every 3 seconds. All onboard power supplies and chips checked and ok. Suspect corrupted BIOS
          BIOS dump attached
          • hoaca388
            Badcaps
            • Jan 2022
            • 12419
            BIOS dump attached
            HP Pavilion Laptop 14-dv1629na (519L4EA
            ​https://www.badcaps.net/donate
            • Darren Hibbert
              • 116
              Thanks but think there is something wrong with this BIOS.
              When I program the BIOS, the laptop will not come on at all or show a power or charge light and is completely dead , but as soon as I put the old BIOS back on it, it responds as it did before. So think there is something wrong with it.
              • hoaca388
                Badcaps
                • Jan 2022
                • 12419
                There's no such thing, it's the full bios from HP.
                • Darren Hibbert
                  • 116
                  I can't understand then why laptop is completely dead with the new BIOS file but powers up when I put the old corrupt BIOS back on it 🤷🤷🤷
                  • peste
                    • Dec 2016
                    • 13747
                    • ROMANIA
                    try this too..
                    bios extracted from the HP site update for.HP Pavilion Laptop 14-dv1629na (519L4EA)
                    DMI+KEYWIN 500000 - 50103F​
                    • Aditya11ttt
                      Adi
                      • Feb 2019
                      • 192
                      • India
                      Was your case solved ??
                      do you still have the laptop ?
                      • Md Jibrail
                        • Mar 2023
                        • 21
                        • Saharsa
                        Originally posted by peste
                        try this too..
                        OKK BIOS
                        • glovecaps
                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                          by glovecaps
                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                          11-25-2024, 04:23 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • Wahaz
                          by Wahaz
                          10-30-2023, 08:42 PM
                        • hotcrossedbuns999
                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                          by hotcrossedbuns999
                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                          3. I could only locate two chips that look like bios chips. Could someone verify this
                          01-03-2025, 12:32 PM
                        • GardevoirForEver
                          Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
                          by GardevoirForEver
                          I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
                          Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
                          The motherboard of my ASUS...
                          Today, 04:30 PM
