HP 14-dv1629na BIOS request. Motherboard DA0G7GMB8F0 REV.F
  • Darren Hibbert
    • 110
    Hi.
    I'm looking for the Bios Bin file to reflash my bios.
    Thanks.
    • 20966
    Originally posted by Darren Hibbert
    Hi.
    Thanks.
    Post your bios backup and laptop serial number,as per the rules https://www.badcaps.net/forum/troubl...before-posting
    Read Vesko`s HP guides to ID your bios BID
    7. Extracting BIOS/EC firmware from update packages
    https://www.badcaps.net/forum/troubl...=8#post1622426
    7.2.4. HP
    [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948 and
    [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
    • Darren Hibbert
      • 110
      Sorry, my mistake. Will get the serial number a bit later.
        • 20966
        No problem.Post your backup and someone will help
        • Darren Hibbert
          • 110
          HP 14-dv1629na model number.
          Serial Number - 5CD1466KB9
          Laptop turns on and off every 3 seconds. All onboard power supplies and chips checked and ok. Suspect corrupted BIOS
          BIOS dump attached
          • hoaca388
            Badcaps
            • Jan 2022
            • 11773
            BIOS dump attached
            HP Pavilion Laptop 14-dv1629na (519L4EA
            • Darren Hibbert
              • 110
              Thanks but think there is something wrong with this BIOS.
              When I program the BIOS, the laptop will not come on at all or show a power or charge light and is completely dead , but as soon as I put the old BIOS back on it, it responds as it did before. So think there is something wrong with it.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11773
                There's no such thing, it's the full bios from HP.
                • Darren Hibbert
                  • 110
                  I can't understand then why laptop is completely dead with the new BIOS file but powers up when I put the old corrupt BIOS back on it 🤷🤷🤷
                  • peste
                    • Dec 2016
                    • 12844
                    • ROMANIA
                    try this too..
                    bios extracted from the HP site update for.HP Pavilion Laptop 14-dv1629na (519L4EA)
                    DMI+KEYWIN 500000 - 50103F​
                    • Aditya11ttt
                      Adi
                      • Feb 2019
                      • 181
                      • India
                      Was your case solved ??
                      do you still have the laptop ?
                      • Md Jibrail
                        • Mar 2023
                        • 19
                        • Saharsa
                        Originally posted by peste
                        try this too..
                        OKK BIOS
                        • glovecaps
                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                          by glovecaps
                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                          11-25-2024, 04:23 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • Wahaz
                          by Wahaz
                          10-30-2023, 08:42 PM
                        • hotcrossedbuns999
                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                          by hotcrossedbuns999
                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                          3. I could only locate two chips that look like bios chips. Could someone verify this
                          01-03-2025, 12:32 PM
                        • OKRPKCOMP
                          PW-CI7B75A-MA TOWER SYSTEM MOTHERBOARD Bios Request
                          by OKRPKCOMP
                          I am sorry i wants ok bios without serial no
                          I recieved only motherboard with bios error. dont have serial no etc. Perhaps somebody already changed its bios, i am not confirm. No display. Ram Volts, processor volts, 3v+5v all are ok
                          clock is ok, ossilation is ok. processor worns, fan spins but no display
                          Board code: PW-CI7B75A-MA
                          Attaching available bios backup with motherboard picture
                          Regard, thanks in advance...
                          02-20-2024, 10:45 AM
