Lenovo Y40-80 bios
  • goldhawks
    • May 2024
    • 4
    Lenovo Y40-80 bios
    Hi all, I have a Lenovo Y40-80 that I am trying to remove the Admin password for. There is a password screen that comes up immediately that I can input a user password for (Pic 3) and this will allow me access to Windows or the BIOS, but a majority of the options are grayed out in the BIOS (Pic 4).
    I have attached a picture of my overall chassis and a close up of the chip that I have read (using CH341A and AsProgrammer). I output two files from the chip and compared them (fc /b) and they were the same. I patched the first file (the file felt like it processed too quickly) and then wrote it onto the chip. I started the computer and nothing had changed, it quickly just showed the password screen again. I decided to compare the original to the patched files and they were the same, so it seems like things didn't get patched correctly.
    Could anyone patch my original file or guide me to where in the process I've gone wrong? Thanks
  • peste
    • Dec 2016
    • 13122
    • ROMANIA
    read..https://www.badcaps.net/forum/troubl...before-posting
    postS/N,(TYPE),motherboard model,etc...
    • SoporteNetFe
      • Aug 2021
      • 119
      • Argentina
      Lenovo Y40-80
      Model: 80FA0018US
      Serial: MP079V15
      BOARD: ZIVY1 LA-B131P Rev: 1.0
      BIOS: B5CN34WW​
      • goldhawks
        • May 2024
        • 4
        Here is a picture of the bottom of my case. Thanks to soportenetfe for helping out and posting information as well!
        • LEO037_2029_
          BIOS_LEGEND
          • Nov 2023
          • 83
          • Argentina
          @goldhawks​ hi,,, try this bios its clean from password, i edit for you. good luck try and tell me if work for you
          • goldhawks
            • May 2024
            • 4
            Hi, thank you for trying. I could not get it to work unfortunately. Computer would power on, but there was only a black screen even after a long period of time (10 minutes or so) and multiple restarts. I reflashed the original back, so nothing lost, just back where I started.
            I am using the CH341A with a clip and I have noticed that I get consistent scans while it's clipped up, but they are not consistent after it's been unclipped and reclipped. I have taken another scan after my most recent clip and will leave that attached. If anyone could try and patch the scan attached, it would be most appreciated.
            I have tried to patch this scan and the script was again very quick and did not ultimately change anything upon comparison, but I am unsure if there is anything that I am doing wrong or missing even after reading everything that I could.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12032
              Try , if not work , find hardware error
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1230
                • France
                Y40-80 remove the Admin password
                Cliquez sur l'image pour la voir en taille r?elle   Nom : 		Nouveau Image bitmap.png  Affichages :	0  Taille :		443,9 Ko  ID : 			3339722
                21000h and 21800h in padding
                Cliquez sur l'image pour la voir en taille r?elle   Nom : 		image.png  Affichages :	0  Taille :		757 octets  ID : 			3339723
                Cliquez sur l'image pour la voir en taille r?elle   Nom : 		image.png  Affichages :	0  Taille :		1,3 Ko  ID : 			3339724
                a little late, but for information
                • Forest79
                  by Forest79
                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                  07-23-2023, 07:39 AM
                • survivalbloke
                  Unable to extract bios file from Lenovo bios exectuable
                  by survivalbloke
                  I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                  Code:
                  "innoextract 7wcn38ww.exe"
                  it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                  The trouble I'm having is that I'm not getting the newly...
                  06-12-2024, 07:55 AM
                • maanee11
                  Help to get Lenovo BIOS bin file for Thinkpad T560
                  by maanee11
                  Hello Everyone,
                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                  05-15-2022, 11:59 AM
                • survivalbloke
                  Unable to extract Lenovo BIOS file from installer
                  by survivalbloke
                  I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                  I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                  How can...
                  07-16-2025, 03:21 PM
                • pcwhiz24
                  Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                  by pcwhiz24
                  Model: Lenovo IdeaPad 3 14ADA05 81W0
                  S/N: PF2BZS7D
                  I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                  I already have a CH341A programmer...
                  04-07-2025, 07:10 PM
