Unable to extract Lenovo BIOS file from installer
This topic has been answered.
  • survivalbloke
    • Aug 2021
    • 321
    I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
    I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
    How can I extract the BIOS from this executable?
  • Answer selected by survivalbloke at 07-17-2025, 10:27 AM.
    m1ch43lzm
    • Mar 2019
    • 2950
    • Peru
    It's the .rom file, extract with https://github.com/LongSoft/InsydeIm...actor/releases
    Should give you a 32,768KB file
    Always make a backup of the contents on your BIOS chip before trying to flash anything with an external programmer, you need a programmer that supports 1.8V chips, otherwise you risk frying the BIOS chip, or the CPU/motherboard, as all Ryzen laptops use 1.8V chips
    If you plan to use a CH341A, make sure you get an additional 1.8V adapter for it, or get the version with a voltage selector switch; i say this because the black CH341A version is more common, and some of those have a design defect that sends 5V to the data lines, but power the BIOS IC with 3.3v
    Depending on your BIOS chip, get the correct socket adapter either SOP8 or WSON8 8x6
    Make sure you read the contents 3 times, save each file and compare with a hex editor, if the 3 dumps are exactly the same, and not full of FF FF FF ..., likely you got a good read
    If you just want to update the BIOS, run the .exe
    • m1ch43lzm
      • Mar 2019
      • 2950
      • Peru
      • survivalbloke
        • Aug 2021
        • 321
        Thank you for that! I have a reader and have flashed chips before(I'm a repair shop), but I never thought to take 3 copies of the BIOS backup - that's excellent advice!
        The machine will not post, so I Was in an attempt to copy the serial number info from the original BIOS to the new one. I'll report back, and thank you for that link!
        • survivalbloke
          • Aug 2021
          • 321
          OMG, I was using the wrong extractor lol.
          • survivalbloke
            • Aug 2021
            • 321
            Question: What will be the result if I just flash the clean BIOS file I extracted from the Lenovo executable?
            • m1ch43lzm
              • Mar 2019
              • 2950
              • Peru
              You'll lose the DMI data (serial, model name, machine type, ...) and the embedded windows key
              Find $LENV with a hex editor on the bios dump and copy those blocks to the clean BIOS, on Lenovo the DMI data is encrypted
              Laptop should boot anyway if it's only a BIOS issue
              If you still need help, go to the bios request subforum, find an existing thread for your model, or create a new one if it doesn't exist, and post there the required info (laptop model, serial number, machine type/MTM, board number (NM-xxxx)), and attach the (corrupt) BIOS dump in that post, someone there will make a new BIOS for you, or supply a clean BIOS with a note indicating the offsets you should copy from
              • survivalbloke
                • Aug 2021
                • 321
                Thanks! Super helpful AND I've learned something!
                • to5it0
                  by to5it0
                  10-24-2025, 01:35 AM
                • survivalbloke
                  Unable to extract bios file from Lenovo bios exectuable
                  by survivalbloke
                  I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                  Code:
                  "innoextract 7wcn38ww.exe"
                  it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                  The trouble I'm having is that I'm not getting the newly...
                  06-12-2024, 07:55 AM
                • Forest79
                  by Forest79
                  07-23-2023, 07:39 AM
                • Do_Yuri
                  Lenovo IdeaPad 3 15ADA05 (81W1) — cannot enter BIOS, system always boots in Legacy mode
                  by Do_Yuri
                  Hello.
                  I’m trying to diagnose a Lenovo IdeaPad 3 15ADA05 (Model 81W1).
                  Hardware
                  Model: Lenovo IdeaPad 3 15ADA05 (81W1)
                  BIOS version: E8CN34WW
                  Internal drive: NVMe SSD (detected normally)
                  Symptoms
                  BIOS Setup is almost impossible to enter.
                  Pressing F2 during power-on usually freezes on the Lenovo logo or is ignored.
                  The Novo button opens the Novo Menu, but selecting BIOS Setup...
                  08-01-2026, 01:58 PM
                • yellowtiger
                  Lenovo Slim 7i 14IMH9 - Failed BIOS Update and Stuck in Boot Loop - BIOS Request
                  by yellowtiger
                  Hello Everyone,
                  I have a Lenovo Slim 7i 14IMH9 that got stuck in a boot loop with black screen after a failed BIOS update through Lenovo Vantage.
                  Here are my laptop details:
                  - Model: Lenovo Slim 7i 14IMH9
                  - Serial Number: YX09M0K7
                  - Machine type: 83D80003US
                  **Problem:**
                  About two weeks ago a BIOS update for this laptop failed and the laptop has been stuck in a boot loop with black screen ever since. Now when I press the power button, the keyboard lights come on and the fan starts running. However, the screen remains black. The laptop...
                  06-14-2026, 11:04 AM
