hp 640 g10 password bios
    HELLO EVERYONE
    please can someone UNLOCK this dump
    :HP EliteBook 640 14 inch G10 Notebook PC
    SerialNumber:5CD4445USQ
      Originally posted by Ali_Khan View Post
      HELLO EVERYONE
      Upload both files
      Become a Badcaps supporter
      Thanks to all supporters.
        need help unlocking my password protected BIOS with 256mbit flash memories. RCUnlocker won't do due to size.
        Model: HP Elitebook 640 G10
        Serial: 5CD3471T1G
        ProdID: 736AH7AV
        Something I missed?
          SMDFlea commented
          Editing a comment
          Post moved to 640 G10 topic.
        #64
        Serial: 5CD3471T1G
        ProdID: 736AH7AV
        Something I missed?
        hi try
          Please, repair my bios.
          DAOX8TMB8E0 rev E
          Sn: 5CD3147LSY
          I have 2 long and 2 short beeps.
          Thank You
          post merged..
            DAOX8TMB8E0 rev E
            Sn: 5CD3147LSY
            Thank You
            hi try
              Don't work.
              Laptop is dead. only yelow led blinks
                Originally posted by shiyab View Post
                hi try
                unfortunately writing this back to main ROM does not do the trick.
                HP Sure Start Recovery detected an unauthorized change to the secure boot keys.
                Reboot
                The BIOS has recovered its identity from the Embedded Controller due to data mismatch
                Reboot
                HP Sure Start detected corruption in the Intel Management Engine firmware. Select Continue to complete the full recovery process of Intel Management Engine firmware.
                Reboot
                Windoze
                Best regards,
                Johan
                  Serial: 5CD3471T1G
                  ProdID: 736AH7AV
                  Something I missed?
                  read also EC chipset and post it here. And use BCU to read DMI with original bios+EC, you'll need it to write it back.
                    Serial: 5CD3471T1G
                    ProdID: 736AH7AV
                    Something I missed?
                    Send to you, try
                      The EC is in the original archive together with main. Unsure what DMI means but I have now read out the config with BCU using /getconfig.
                        DMi is data machine ID (serial, built id, sku, etc) you'll find them in file got with BCU. After writing files I provide you (write both main+EC) your laptop will enter in manufacturing program mode (MPM). At 1st boot enter in bios setup (F10) and apply factory defaults. after that let it boot in windows and read again DMI with BCU, open both files and fill empty fields from last file with values got in 1st file, including MAC Adress. Also move * from "Mpm Mode" from Enable to Disable, save file then use BCU to write new file. I use commands "biosconfigutility /get:lock.txt" and " biosconfigutility /set:new.txt " (or whatever you named your files got with BCU, I am using BCU v4.0)
                        good luck!
                          640 g10 DA0X8TMB8E0 REV-E LOCK
                          UNLOCK PLZ
                          Serial Number: 5CD3487R7N
                          Product #/SKU : 9F4G4PA#ACJ
                          CT Number: PRVNR058JIV3TW
                          Description: HP EliteBook 640 14 inch G10
                          BuildID: 23WWKRBZ602#SACJ#DACJ
                          Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawcAeMfPgSguhKjhk8mEmVn7nVpDpVpnpqprqMqz.3e
                          MAC Address : D0:AD:08:B3:2BE
                            good luck!
                            Originally posted by minhdigital View Post
                            Send to you, try
                            The main file causes NeoProgrammer to crash with the not so useful error message "file not open". The same goes for the EC file from post #70, Unlock.rar.
                            So I don't have a complete package where both files work.
                            Is NeoProgrammer 2.2.0.10 not recommended? I just picked one of the mentioned applications from some intro forum post.
                              Hello everyone
                              please help me to un unlock password bios for HP 645 G10
                              I used Tiny Hexer In the first boot BIOS has recovered identity from MAIN
                              SN 5CD340FQ19
                              BIOS V77 VER 01.03.01
                                Originally posted by volcour View Post
                                Hello everyone
                                SN 5CD340FQ19
                                first boot press f10 apply factory defaults and restart 2nd boot reset security settings to defaults exit.
                                use bcu
                                This DMI is extracted from your main.
                                Serial Number: 5CD3497XYC
                                Product #/SKU: 917G0EC#ABF
                                CT Number: PRVNR068JIW19B
                                Description: HP EliteBook 650 15.6 inch G10
                                BuildID: 23WWKRBZ602#SABF#DABF
                                Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAfPguhKhkjhk8mEn7nVpDpVpnpqprqMqz.FQ
                                MAC Address : D0:AD:08:B5:B5:EA
                                  use bcu
                                  Laptop not turning on after flash this main bios
                                    use bcu
                                    I tried many times laptop not turning on with this file pls send me another file
                                      Please unlock password hp elitebook 640 g10
                                      Número del producto: 87D79EC#ABM Número de serie: 5CD408C1M0
                                      Placa del sistema
                                      8B88 KBC Version 52.39.00
                                      BIOS del sistema
                                      V75 Ver. 01.07.01
                                      Product number: 87D79EC#ABM Serial number: 5CD408C1M0
                                      System board
                                      System BIOS
                                      V75 Ver. 01.07.01
                                      in English please..
                                        hi guys i need help unlocking computrace and admin password for this machine
                                        hp 640 g10 i5 10th gen
                                        ssn:5cd425gm2z
                                        thanks in advance
