hp 640 g10 password bios
  • Ali_Khan
    • Dec 2023
    • 13
    • Egypt
    #61
    HELLO EVERYONE
    please can someone UNLOCK this dump
    :HP EliteBook 640 14 inch G10 Notebook PC
    SerialNumber:5CD4445USQ
    • hoaca388
      Badcaps
      • Jan 2022
      • 12268
      #62
      Originally posted by Ali_Khan
      HELLO EVERYONE
      Upload both files
      • un1corn
        • May 2024
        • 5
        • Sweden
        #63
        need help unlocking my password protected BIOS with 256mbit flash memories. RCUnlocker won't do due to size.
        Model: HP Elitebook 640 G10
        Serial: 5CD3471T1G
        ProdID: 736AH7AV
        Something I missed?
          SMDFlea commented
          Editing a comment
          Post moved to 640 G10 topic.
      • shiyab
        • Sep 2023
        • 1592
        • india
        #64
        Serial: 5CD3471T1G
        ProdID: 736AH7AV
        Something I missed?
        hi try
        • max2711
          • Jan 2012
          • 62
          • Croatia
          #65
          Please, repair my bios.
          DAOX8TMB8E0 rev E
          Sn: 5CD3147LSY
          I have 2 long and 2 short beeps.
          Thank You
          post merged..
          • shiyab
            • Sep 2023
            • 1592
            • india
            #66
            DAOX8TMB8E0 rev E
            Sn: 5CD3147LSY
            Thank You
            hi try
            • max2711
              • Jan 2012
              • 62
              • Croatia
              #67
              Don't work.
              Laptop is dead. only yelow led blinks
              • un1corn
                • May 2024
                • 5
                • Sweden
                #68
                Originally posted by shiyab
                hi try
                unfortunately writing this back to main ROM does not do the trick.
                HP Sure Start Recovery detected an unauthorized change to the secure boot keys.
                Reboot
                The BIOS has recovered its identity from the Embedded Controller due to data mismatch
                Reboot
                HP Sure Start detected corruption in the Intel Management Engine firmware. Select Continue to complete the full recovery process of Intel Management Engine firmware.
                Reboot
                Windoze
                Best regards,
                Johan
                • volinakis
                  • Jan 2021
                  • 2872
                  • N/A
                  #69
                  Serial: 5CD3471T1G
                  ProdID: 736AH7AV
                  Something I missed?
                  read also EC chipset and post it here. And use BCU to read DMI with original bios+EC, you'll need it to write it back.
                  • minhdigital
                    • Nov 2022
                    • 764
                    • Vietnam
                    #70
                    Serial: 5CD3471T1G
                    ProdID: 736AH7AV
                    Something I missed?
                    Send to you, try
                    • un1corn
                      • May 2024
                      • 5
                      • Sweden
                      #71
                      The EC is in the original archive together with main. Unsure what DMI means but I have now read out the config with BCU using /getconfig.
                      • volinakis
                        • Jan 2021
                        • 2872
                        • N/A
                        #72
                        DMi is data machine ID (serial, built id, sku, etc) you'll find them in file got with BCU. After writing files I provide you (write both main+EC) your laptop will enter in manufacturing program mode (MPM). At 1st boot enter in bios setup (F10) and apply factory defaults. after that let it boot in windows and read again DMI with BCU, open both files and fill empty fields from last file with values got in 1st file, including MAC Adress. Also move * from "Mpm Mode" from Enable to Disable, save file then use BCU to write new file. I use commands "biosconfigutility /get:lock.txt" and " biosconfigutility /set:new.txt " (or whatever you named your files got with BCU, I am using BCU v4.0)
                        good luck!
                        • TechNoDev
                          • Nov 2024
                          • 7
                          • India
                          #73
                          640 g10 DA0X8TMB8E0 REV-E LOCK
                          UNLOCK PLZ
                          Serial Number: 5CD3487R7N
                          Product #/SKU : 9F4G4PA#ACJ
                          CT Number: PRVNR058JIV3TW
                          Description: HP EliteBook 640 14 inch G10
                          BuildID: 23WWKRBZ602#SACJ#DACJ
                          Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawcAeMfPgSguhKjhk8mEmVn7nVpDpVpnpqprqMqz.3e
                          MAC Address : D0:AD:08:B3:2BE​
                          • un1corn
                            • May 2024
                            • 5
                            • Sweden
                            #74
                            good luck!
                            Originally posted by minhdigital
                            Send to you, try
                            The main file causes NeoProgrammer to crash with the not so useful error message "file not open". The same goes for the EC file from post #70, Unlock.rar.
                            So I don't have a complete package where both files work.
                            Is NeoProgrammer 2.2.0.10 not recommended? I just picked one of the mentioned applications from some intro forum post.
                            • volcour
                              • Dec 2015
                              • 93
                              • algiria
                              #75
                              Hello everyone
                              please help me to un unlock password bios for HP 645 G10
                              I used Tiny Hexer In the first boot BIOS has recovered identity from MAIN
                              SN 5CD340FQ19
                              BIOS V77 VER 01.03.01​
                              • rex98
                                • Feb 2023
                                • 1289
                                • Mandaue CEBU, Philippines
                                #76
                                Originally posted by volcour
                                Hello everyone
                                SN 5CD340FQ19
                                first boot press f10 apply factory defaults and restart 2nd boot reset security settings to defaults exit.
                                use bcu
                                This DMI is extracted from your main.
                                Serial Number: 5CD3497XYC
                                Product #/SKU: 917G0EC#ABF
                                CT Number: PRVNR068JIW19B
                                Description: HP EliteBook 650 15.6 inch G10
                                BuildID: 23WWKRBZ602#SABF#DABF
                                Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAfPguhKhkjhk8mEn7nVpDpVpnpqprqMqz.FQ
                                MAC Address : D0:AD:08:B5:B5:EA​
                                • volcour
                                  • Dec 2015
                                  • 93
                                  • algiria
                                  #77
                                  use bcu
                                  Laptop not turning on after flash this main bios
                                  • volcour
                                    • Dec 2015
                                    • 93
                                    • algiria
                                    #78
                                    use bcu
                                    I tried many times laptop not turning on with this file pls send me another file
                                    • lizquierdos
                                      • Jan 2025
                                      • Mexico
                                      #79
                                      Please unlock password hp elitebook 640 g10
                                      Número del producto: 87D79EC#ABM Número de serie: 5CD408C1M0
                                      Placa del sistema
                                      8B88 KBC Version 52.39.00
                                      BIOS del sistema
                                      V75 Ver. 01.07.01
                                      Product number: 87D79EC#ABM Serial number: 5CD408C1M0
                                      System board
                                      System BIOS
                                      V75 Ver. 01.07.01​
                                      in English please..
                                      • retrooo
                                        • Mar 2017
                                        • 92
                                        • mexico
                                        #80
                                        hi guys i need help unlocking computrace and admin password for this machine
                                        hp 640 g10 i5 10th gen
                                        ssn:5cd425gm2z
                                        thanks in advance
                                        • Buzzfuzz2k
                                          Bios password removal on a Unowhy dump
                                          by Buzzfuzz2k
                                          Hi Everyone,
                                          I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                          The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                          the Computer is a Unowhy small pc
                                          N° UYM6524702229
                                          After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                          My first attempt was to get the bios dump from windows...
                                          11-13-2023, 07:37 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • ArkzG
                                          [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                          by ArkzG
                                          Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                          What I currently have available:
                                          - Model: FA506NF (2021)
                                          - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                          - Tools: CH341A programmer ready to use
                                          Does anyone have either a clean 2MB .bin dump of this model,...
                                          09-26-2025, 09:34 PM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
