Lenovo Thinkpad T495 AMD bios password locked
  • gsoft
    • Jul 2023
    • 38
    • Italy
    #61
    Originally posted by Markus1741
    La La ....
    Sorry I don't uderstand can you explain me?
    • volinakis
      • Jan 2021
      • 2872
      • N/A
      #62
      Originally posted by gsoft
      This is the S/N PF-26H4AM.
      Why I can't use the soic clamp?
      this proves once again that you didn't read bios guides! As beginner into bios mod this should be your 1st step, ppl with way more experience than you made that guide. Since you write back bios backup you made with clamps and laptop doesn't start this should tell you that your bios backup is corrupted! And yet you ask "Why i can't use the soic clamp?" !!!
      " It is possible to use clips on SOIC-8 ICs to avoid desoldering, however it is *very unreliable* and will often lead to an empty or corrupt dump. Avoid whenever possible.
      If you insist on using a clip, then make sure the programmer uses an additional buffer and line driver for SPI.The T48 and T56 has it built-in.
      It is recommended to desolder the chip and use an adapter board or socket."
      • gsoft
        • Jul 2023
        • 38
        • Italy
        #63
        Ok yes I yet read it but I was thinking what you wrote was because I don't use the 1.8V adapter. Now is all clear.
        So please let me know why you ask me the serial number? it is possible to generate a new bios dump with it?
        Really thanks
        • volinakis
          • Jan 2021
          • 2872
          • N/A
          #64
          La La ....
          once again you try to look smarter than you are! if he wrote back his bios backup and laptop doesn't work what's this telling you?
          • volinakis
            • Jan 2021
            • 2872
            • N/A
            #65
            Really thanks
            yes, I will try to build a new bios from bios update, patch it and see how it works.
            • gsoft
              • Jul 2023
              • 38
              • Italy
              #66
              Great!!!
              1000 thanks
              • volinakis
                • Jan 2021
                • 2872
                • N/A
                #67
                Great!!!
                1000 thanks
                1st use patched file to unlock bios following steps described in autopatcher:
                [ HOW TO USE THE PATCH ]
                STEP 1: Flash and replace current BIOS with the generated patch file
                STEP 2: Boot the machine
                STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                STEP 4: Enter any character when asked for Supervisor Password
                STEP 5: Press enter when it shows Hardware ID
                STEP 6: Press space bar 2x when asked
                STEP 7: Turn off machine
                STEP 8: Restore original BIOS
                STEP 9: Reset BIOS settings to factory default
                at step 8 use T495_new.bin Because your backup is corrupted I'm not sure your DMI is ok, if you get message that serial, MTM, etc. is missing use Lenovo Maintenance Utility to restore original serial, MTM.
                • gsoft
                  • Jul 2023
                  • 38
                  • Italy
                  #68
                  Thank you I will try it but to make sure I do things right:
                  I must use the 1.8V adapter and I have to desolder the chip. Is right?
                  • gsoft
                    • Jul 2023
                    • 38
                    • Italy
                    #69
                    The 1.8V adapter just arrive I follow this steps but after patching with the generated patch file (STEP1) the fan start fast but screen stay black and after the laptop shutdown itself.
                    I'm trying to power one the laptop with the ch341 clamp attached but not inserted to usb because I'm not able to desolder it and I spend some hours to fit the clamp.
                    Please can you help me?
                    • volinakis
                      • Jan 2021
                      • 2872
                      • N/A
                      #70
                      so ... if you got an faulty bios backup with clamps how do you expect to write bios chipset in a good way ... with same clamps? Think, is for free!
                      • gsoft
                        • Jul 2023
                        • 38
                        • Italy
                        #71
                        You are right but it was my mistake because I try to read and flash with the clamp not fitted correctly but now after 10000 try I fit it and bacause I'm not able to desolder it I want to try to restore the laptop in this way. I disconnect the ch431a but not the clamp and now the laptop play some strange sounds (bip bip...) and nothing else
                        ​​I not want to disconnect the clamp because if I have to flash another firmware I not want to make again 10000 try to fit it.
                        • volinakis
                          • Jan 2021
                          • 2872
                          • N/A
                          #72
                          look around bios chipset if you didn't damage any component during 10000 tries, it happens
                          • gsoft
                            • Jul 2023
                            • 38
                            • Italy
                            #73
                            Finally I get it working again by flashing the #22 bin file...Now I have a no password bios!!! So the problem was not using 1.8v adapter
                            Thank you for your support!!
                            Just last question: why you say to restore original dump if with patched one all is ok?
                            • SAHILSHAIK
                              • Jul 2024
                              • 27
                              • india
                              #74
                              Originally posted by Maxpower3
                              try this one to test
                              Click image for larger version Name:	chk.jpg Views:	0 Size:	231.5 KB ID:	3234910
                              Click image for larger version Name:	cks.jpg Views:	0 Size:	320.2 KB ID:	3234909
                              Click image for larger version Name:	chk2.jpg Views:	0 Size:	349.6 KB ID:	3234911
                              SIR COULD U PLEASE TELL US IN STEPS
                              • Markus1741
                                • Sep 2020
                                • 917
                                • N/A
                                #75
                                Hello watch this video​ ...
                                https://www.youtube.com/watch?v=3BB--9VU0R0
                                • MadaCrx
                                  • Mar 2025
                                  • 3
                                  • Romania
                                  #76
                                  Hello. I bought this laptop T495 and i think he have autopilot or MDM i don't know sure.. but the thing is that i can't install windows on it.. after i install windows i have to log somewhere.. this happened few days ago.. but now.. after i tried few things i generated another UUID and now this laptop can't connect to that server or idk how to call it... "mother ship ". I will attach bellow one picture. And one more thing. I saw that in bios i have OA3 license installed, preinstalled license. And one more thing, the laptop had supervisor password on bios.. but i managed remove it and to disable everything on bios that could block me to install the windows. It's there a way to resolve my problem? Thank you very much!
                                  • Nagyesz
                                    • May 2024
                                    • 124
                                    • Hungary
                                    #77
                                    Hi y'all. Would anyone happen to have some advice? After I did the Lenovo autopatcher, no post, black screen. I tried with a different bios as well, same result. Original bios working, but it needs password.
                                    The original bios is in the attachments as well the patched
                                    FA495 NM-C131 rev 1
                                      • 21654
                                      Post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
                                      • Abhishek Keerthi
                                        • Mar 2025
                                        • India
                                        #79
                                        Hi! I tried patching and writing the bios to my ThinkPad T495 but it seems that the original dump was corrupted. Now the laptop doesn't boot even when I flash the original dump. Anyway to save the machine ?
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • kicker12
                                          Thinkpad T495 locked BIOS
                                          by kicker12
                                          Hey! I have a T495 with BIOS password... I tried the LPC bus shorting BUT I haven't been able to get it to work (tamper error, asking for password, various errors): I guess I have now tried thousand times...
                                          Hence... Here is its BIOS dump: anyone willing to check/help??? MANY THANKS!
                                          Model: Thinkpad T495
                                          Motherboard: NM-C131
                                          Serial Number: PF-1TG5RR...
                                          09-19-2025, 04:26 AM
                                        • fulaphex
                                          Lenovo Thinkpad X13 Gen 3 AMD locked bios
                                          by fulaphex
                                          hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
                                          I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....
                                          07-09-2025, 07:04 PM
                                          Lenovo ThinkPad T495 Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T495 boardview and T495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 04:10 PM
                                          09-06-2024, 03:30 PM
