Lenovo Thinkpad T495 AMD bios password locked
  • gsoft
    • Jul 2023
    • 38
    • Italy
    #41
    Originally posted by volinakis
    let me understand: you used a patched bios from another laptop and now if you write back original bios laptop has black screen? Post original bios backup and serial number, as in rules and explain what you did.
    Thank you for answer.
    I try to explain what I do.
    I use patched bios posted in #22 and now the laptop non boot.
    • volinakis
      • Jan 2021
      • 2872
      • N/A
      #42
      did you write back original bios and laptop doesn't work? Using clips is the best way to brick a laptop.
      • gsoft
        • Jul 2023
        • 38
        • Italy
        #43
        Yes I use clips. I try to write back the original bios and not work but I have a doubt about the quality of the backup I made...
        another dubt is about the ch341a, the chip is a 1.8V and I not use the 1.8V adapter...
        • volinakis
          • Jan 2021
          • 2872
          • N/A
          #44
          congratulation, you have a branded lenovo door stopper. Before bricking another laptop read BIOS GUIDES of this forum
          https://www.badcaps.net/forum/troubl...t=phoenix+bios
          • gsoft
            • Jul 2023
            • 38
            • Italy
            #45
            Ok so do you think I fired the chip? But if connect it to the ch431a the software can read and detect it...
            • volinakis
              • Jan 2021
              • 2872
              • N/A
              #46
              since you write back original file and it doesn't work means your backup is fcked up. Use right tools (described in bios tools) if you want to have good results and also check components around bios chipset, clamps may damage them.
              • gsoft
                • Jul 2023
                • 38
                • Italy
                #47
                Sorry but I need some explanation because I not find it on forum, please can you help me to understand?
                - I read about an autopatcher bat it cannot be used for my laptop because is AMD not Intel
                - I ask here and tha answer was to patch with file posted in #22
                - I read about using ch341a but nowhere i find info about the 1.8V adapter
                So in my situation what I have to do?
                I ordered a 1.8V adapter when it arrives can I try to use it to patch again or there is nothing I can do now because I fried the chip?
                I think, due I make the backup without the 1.8V adapter, my copy of original firmware is not good. There is a way to get an original bios bin or it is different for every laptop?
                Thanks again for you patience
                • volinakis
                  • Jan 2021
                  • 2872
                  • N/A
                  #48
                  1st step is to acquire a good bios backup. Since your chipset is 1.8V YOU HAVE TO USE 1.8V adapter. Best way to have a good bios backup is to remove bios chipset from board. Having CH341A use AsProgrammer to backup bios and read 3-4 times until you have 2 identical backups bin files. ALL STEPS ARE DESCRIBED IN BIOS GUIDES but you fail to understand that YOU HAVE TO READ IT!
                  • gsoft
                    • Jul 2023
                    • 38
                    • Italy
                    #49
                    Ok thanks but now because I have tried many times to write the chip with patched .bin I can't make a good backup of original firmware So what can I do? Where can I find an original bios bin file?
                    • Markus1741
                      • Sep 2020
                      • 917
                      • N/A
                      #50
                      Hello try this new hash patched file from your original file from #18
                      https://www.badcaps.net/forum/troubl...61#post3261861
                      • gsoft
                        • Jul 2023
                        • 38
                        • Italy
                        #51
                        Tankyou Markus1741 but is better I wait the 1.8V adapter arrives and try with it or I can also try without it? Do you think patched file is a good dump also if I do it without the adapter?
                        • Markus1741
                          • Sep 2020
                          • 917
                          • N/A
                          #52
                          Well I can't tell you that because I don't know exactly what kind of chip you have.
                          I have a Winbond 25Q128FVSQ, a datasheet from Winbon shows it as 25Q128FV with 2.7V - 3.6V.
                          I can't even say whether it is only 1.8V.
                          You yourself have never published which chip you have.
                          • gsoft
                            • Jul 2023
                            • 38
                            • Italy
                            #53
                            You are right I have this chip on t495: Winbond 25Q128FWSQ
                            in datasheet I read 1.8V but until now I make read and write without the 1.8V adapter
                            • Markus1741
                              • Sep 2020
                              • 917
                              • N/A
                              #54
                              Hello my patch is based on this guide.​
                              https://www.badcaps.net/forum/troubl...55#post3233555
                              • gsoft
                                • Jul 2023
                                • 38
                                • Italy
                                #55
                                Ok but your chip is 3.6V mine is 1.8V so I must use the adapter?
                                • volinakis
                                  • Jan 2021
                                  • 2872
                                  • N/A
                                  #56
                                  it will not work because Volume_NVRAM_EfiSystemNvDataFvGuid is not patched. that's why autopatcher doesn't work on this model ... But you are close to discover warm water ...
                                  And you apply patch to a backup of 1.8V chipset made with 3.3V CH341A programmer with clamps. What's the odds that backup is ok? Think, is for free!
                                  • gsoft
                                    • Jul 2023
                                    • 38
                                    • Italy
                                    #57
                                    So there is no way for me to have a working laptop agaim!? Because I not have a good backup??
                                    • volinakis
                                      • Jan 2021
                                      • 2872
                                      • N/A
                                      #58
                                      there is but you have to remove bios chipset from board with hot air gun and use programmer adapter to write it, then solder back. Write serial number.
                                      • Markus1741
                                        • Sep 2020
                                        • 917
                                        • N/A
                                        #59
                                        La La ....
                                        • gsoft
                                          • Jul 2023
                                          • 38
                                          • Italy
                                          #60
                                          This is the S/N PF-26H4AM.
                                          Why I can't use the soic clamp?
                                          • lucaszmn
                                            by lucaszmn
                                            Problem:
                                            Initial Findings:
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • kicker12
                                            Thinkpad T495 locked BIOS
                                            by kicker12
                                            Hey! I have a T495 with BIOS password... I tried the LPC bus shorting BUT I haven't been able to get it to work (tamper error, asking for password, various errors): I guess I have now tried thousand times...
                                            Hence... Here is its BIOS dump: anyone willing to check/help??? MANY THANKS!
                                            Model: Thinkpad T495
                                            Motherboard: NM-C131
                                            Serial Number: PF-1TG5RR...
                                            09-19-2025, 04:26 AM
                                          • fulaphex
                                            Lenovo Thinkpad X13 Gen 3 AMD locked bios
                                            by fulaphex
                                            hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
                                            I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....
                                            07-09-2025, 07:04 PM
                                            Lenovo ThinkPad T495 Notebook T Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad T495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T495 boardview and T495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 04:10 PM
                                            09-06-2024, 03:30 PM
