Lenovo Thinkpad T495 AMD bios password locked
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
congratulation, you have a branded lenovo door stopper. Before bricking another laptop read BIOS GUIDES of this forum
https://www.badcaps.net/forum/troubl...t=phoenix+bios----------------------------------------------------------------------------------------------------------------------------------------------------------------------
since you write back original file and it doesn't work means your backup is fcked up. Use right tools (described in bios tools) if you want to have good results and also check components around bios chipset, clamps may damage them.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Sorry but I need some explanation because I not find it on forum, please can you help me to understand?
- I read about an autopatcher bat it cannot be used for my laptop because is AMD not Intel
- I ask here and tha answer was to patch with file posted in #22
- I read about using ch341a but nowhere i find info about the 1.8V adapter
So in my situation what I have to do?
I ordered a 1.8V adapter when it arrives can I try to use it to patch again or there is nothing I can do now because I fried the chip?
I think, due I make the backup without the 1.8V adapter, my copy of original firmware is not good. There is a way to get an original bios bin or it is different for every laptop?
Thanks again for you patienceComment
1st step is to acquire a good bios backup. Since your chipset is 1.8V YOU HAVE TO USE 1.8V adapter. Best way to have a good bios backup is to remove bios chipset from board. Having CH341A use AsProgrammer to backup bios and read 3-4 times until you have 2 identical backups bin files. ALL STEPS ARE DESCRIBED IN BIOS GUIDES but you fail to understand that YOU HAVE TO READ IT!Sorry but I need some explanation because I not find it on forum, please can you help me to understand?
Thanks again for you patienceAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello try this new hash patched file from your original file from #18
https://www.badcaps.net/forum/troubl...61#post3261861
Tankyou Markus1741 but is better I wait the 1.8V adapter arrives and try with it or I can also try without it? Do you think patched file is a good dump also if I do it without the adapter?Hello try this new hash patched file from your original file from #18
https://www.badcaps.net/forum/troubl...61#post3261861Comment
Well I can't tell you that because I don't know exactly what kind of chip you have.
I have a Winbond 25Q128FVSQ, a datasheet from Winbon shows it as 25Q128FV with 2.7V - 3.6V.
I can't even say whether it is only 1.8V.
You yourself have never published which chip you have.Comment
Ok but your chip is 3.6V mine is 1.8V so I must use the adapter?Comment
it will not work because Volume_NVRAM_EfiSystemNvDataFvGuid is not patched. that's why autopatcher doesn't work on this model ... But you are close to discover warm water ...Hello try this new hash patched file from your original file from #18
And you apply patch to a backup of 1.8V chipset made with 3.3V CH341A programmer with clamps. What's the odds that backup is ok?
Think, is for free!
Last edited by volinakis; 08-01-2024, 12:16 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
So there is no way for me to have a working laptop agaim!? Because I not have a good backup??
Think, is for free!Comment
Last edited by volinakis; 08-01-2024, 04:18 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
by kicker12Hey! I have a T495 with BIOS password... I tried the LPC bus shorting BUT I haven't been able to get it to work (tamper error, asking for password, various errors): I guess I have now tried thousand times...
Hence... Here is its BIOS dump: anyone willing to check/help??? MANY THANKS!
Model: Thinkpad T495
Motherboard: NM-C131
Serial Number: PF-1TG5RR...-
by fulaphexhello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....-
This specification for the Lenovo ThinkPad T495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T495 boardview and T495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 04:10 PM
- Loading...
